ez_willis
Can anyone recommend strings that have a wound third other than the D'Addario XL110W?
ez_willis said:Can anyone recommend strings that have a wound third other than the D'Addario XL110W?
Thunder33 said:Just curious, what is wrong with the D'Addario?
Zaphod B said:EZ, what kind of music are you playing using the wound third?
Whaaaa??? APL's endorsing a company that isn't Carvin? As far as I know, Carvin doesn't make strings, but if they did, then can I safely assume you'd be all over that?apl said:Hey, ez_, do check out Snake Oil Brand Strings. Shoot an e-mail the head cheese (Dean Farley) and he'll take care of you. He set up me up with a set of 11-14-18w-28-38-50 for the Epi archtop.
IronFlippy said:Whaaaa??? APL's endorsing a company that isn't Carvin? As far as I know, Carvin doesn't make strings, but if they did, then can I safely assume you'd be all over that?
Back on track...
I've always wondered how octaves would sound on the A and G strings if it were wound. You'd probably have to get the guitar set up for it. As far as brands, I dunno. You can get the strings individually and instead of getting a plain G string, you can get a really light gauge D string. Never tried that, so I don't know.
The main reason for a wound G is that many guitars (particularly Fenders, in my experience) produce some really terrible overtones and ringing on an unwound G. There was a long, technically inconclusive discussion about this among techs and pros on the FDP a couple of years ago and the bottom line was that the best way to make it go away completely was to use a wound G. The trick seems to be to get one with a small enough core to still work as commonly expected with the typical .010" set. Personally, I've never felt the expense and hassle of finding string sets like that was worth it, but I can definitely attest to the problem being real.apl said:The wound G sounds richer.
bongolation said:The main reason for a wound G is that many guitars (particularly Fenders, in my experience) produce some really terrible overtones and ringing on an unwound G. There was a long, technically inconclusive discussion about this among techs and pros on the FDP a couple of years ago and the bottom line was that the best way to make it go away completely was to use a wound G. The trick seems to be to get one with a small enough core to still work as commonly expected with the typical .010" set. Personally, I've never felt the expense and hassle of finding string sets like that was worth it, but I can definitely attest to the problem being real.
Zaphod B said:Cool stuff, EZ. Well done!
Lots of wah action goin' on. Are you on vocals as well?
And more accurately, it's spaced for a traditional nickle alloy (nonferrous/nonmagnetic) -wound G. The introduction of stainless and plated-steel windings created all sorts of interesting sonic "artifacts" with pole-compensated vintage Stratocaster pickups, most notoriously "stratitis."apl said:The vintage pole piece on the Strat single coil pickup is cut for a wound G.
bongolation said:And more accurately, it's spaced for a traditional nickle alloy (nonferrous/nonmagnetic) -wound G. The introduction of stainless and plated-steel windings created all sorts of interesting sonic "artifacts" with pole-compensated vintage Stratocaster pickups, most notoriously "stratitis."
The specific unwound G problem to which I was referring is a different matter, and it's of sufficient weirdness that I don't completely accept any one explanation I've heard for it.![]()
bongolation said:The specific unwound G problem to which I was referring is a different matter, and it's of sufficient weirdness that I don't completely accept any one explanation I've heard for it.![]()
freshmattyp said:All my guitars have 12-52's with a wound G, except my Fender Jag which has Flatwound 13's. I have big hands and play pretty hard. The wound G works better for me.
