Outlaws
ggunn said:Silicon is the substance from which diodes and transistors are made. Silicone is the substance from which strippers' bodacious ta-tas are made. Unless the 900 of which you speak has had a boob job, I believe you mean the former. ;^)
What's a clipping path? I know what that is in Photoshop... Anyway, all the diodes I've seen in tube amp schematics have been in the HVDC power supply. I believe that what some folks don't like about them is that they don't let the voltage to the power tubes sag under high demand conditions the way that tube rectifiers do.
No offense intended. I'm stuck at work and I'm bored.
No, I mean the boob job.
But really, they use diodes to clip some of the signal in the preamp for a more buzzy sound...the same way a distortion pedal works.
I don't know what you mean about power tubes vs the rectifier sag. Power tubes compress. A tube rectifier "sag" is because it can't keep up in the reaction time. Thats why they went to solidstate recs for 100 watt amps because at that volume a tube rec just doesn't work. (which is why Mesa's use two and three tubes in their rectifiers)
