Newbie question about wiring...
In an XLR balanced cable, I understand that the two core wires carry the signal (in opposite phase?) to cancel out interference induced in the cable (since both would be affected the same way, right?). SO! for the ground/shield part, what kind of electronics takes place here? I would particularly like to know why this must be independent for each cable, and why a common ground is not sufficient... or is it? I have no idea!
All of this was inspired by seeing a site - http://www.violetaudio.com/index.php?option=com_content&task=view&id=21&Itemid=30 - where they carry balanced signals over cat5 connectors, and charge a HEAP for it... And i wanted to know if that is deserved, or if i could just make them myself for a few bucks (i can solder, and have made leads in the past that work great)
THANKS for any explanations, you can probably see i have no idea
