Doubling you RAM will normally help but sometimes the motherboard can't utilize it. Check that out before you do it. Another hard drive will definitely help but more than likely the answer is to reduce the buffer size to get rid of the clicks and pops.playit said:That's cool. I started recording at 96khz recently and it introduced a couple of problems. Higher latency, plus it seemed like during playback I have more tendency for pops and clicks. So I added some RAM to 1 GB and that still didn't help my latency issue. I guess adding a hard drive would fix the pops and clicks then. What if I went to 2 GB would I possibly be able to lower my buffer size and get better latency?
