wes480
Ok, I've read all about latency - I understand basically what it is. But there are still some real world things that I just don't get based on my experience.
When I first started out I was using an SBLive! card with a radio shack mic plugged into it. I would record a track with my acoustic guitar, and then play that track back while laying down the vocals. Even did some keyboard from time to time.
I'm sure the latency was outstandingly high - and I never adjusted the setting - at that time I didn't know it existed.
However I never had any problem recording things and playing back with them and getting it in sync. Maybe that set the tone for my general apathy to latency. (Granted I wasn't using any effects back then.)
I then upgraded to a Aardvark Q10. Which had zero-latency monitoring and low latency specs and all that. I got Mackie monitors and refined my overall setup, started using newer software that allowed real-time EQ and the like.
Still I never had to fight with it. I was always able to lay down the tracks I wanted, recording them back on top of each other without timing issues.
I don't really use any effects...to this day, besides a little EQ.
Now I have a presonus firepod and have been reading more into it - as far as how you can mix the zero latency signal with the recorded signal.
I don't understand why "zero latency monitoring" is a good thing - if it creates a difference from what you hear out of the monitors, and the pre-recorded tracks coming from the computer. If the point is that you want to be able to play along with those tracks - shouldn't it all just "mix down" together when it goes to the monitors?
I have a grasp on the technical here but not the practical.
Have I just been dodging bullets? Is latency only really an issue when you are using tons of VSTs or effects? If that is the case...why not just track everything first and save the mixing for later - like a good little engineer
What types of latencies are considered "not usable" for tracking/mixing?
I have more questions than answers at this point. Hopefully someone can help. All I know is I've never experienced a problem or been concerned with it...maybe it's just the way I am doing things since I pretty much just multi track (i.e lack of complexity)?
What types of latencies are considered "not usable" for tracking/mixing?I have more questions than answers at this point. Hopefully someone can help. All I know is I've never experienced a problem or been concerned with it...maybe it's just the way I am doing things since I pretty much just multi track (i.e lack of complexity)?
