Hello all
I'm trying to understand Compression.
After reading the following,.....
"We often just want the loudest notes tamed, not broken. This is where compressors come in and with them a RATIO control. All the RATIO control does is set how quiet we want the loudest stuff. If RATIO is set to 1:1, then nothing really happens. Might as well hit BYPASS.
At the other extreme, lets say a ratio of 20:1, then we are probably limiting rather than compressing. In fact the sound would have to get 20dB over the threshold before the compressor lets even 1dB more out. Thats what the 20:1 means.
If the THRESHOLD is set to 2:1, then it only requires the sound to get 2dB hotter to let 1dB more out."
my conclusion is thus.......
If I have a 2:1 ratio and my signal goes 1db over the Threshold then that 1 db will be cut and lost.
If I have a 4:1 ratio, and I go 3 db's over, those 3 db's are
also history.
Would this be correct?
cheers
also history.
cheers
