scottmd06
I'm curious if I can map from the midi-out on my electronic drums into EZDrummer to access more samples... Has anyone successfully done this around these parts? Thanks!
Sweet. Thanks guys! I just might use my Ion iDM02 Module with trigger's on my drummer's acoustic kick, snare, and toms and set up some stereo overheads to catch the cymbals. Midi out from the module to EZ Drummer and mix the overheads in with the midi.
Has anyone here recorded like this with positive results??
...I run an intel core 2 quad Q6600 @ 2.4GHz...
Bit off topic, but why not run that baby @ 3ghz ?![]()
The G0 stepping it hardly breaks a sweat with a bit of an overclock and stays perfectly stable, but the speed gain is certainly noticeable. An 'adequately decent' motherboard contributes towards stability, however anything but the very cheapest should cut it - you don't need anything fancy. As for temps... I have a nice Noctua HSF for mine but I've heard the temps stay low (again, talking about the G0 stepping here... B3 ran a bit hotter) even with the stock cooler.
Just a thought!
