I'm curious......what did you have prior to the DP-24?
you can sync up the DP-24 to a midi sequencer. then you record your mix as a midi sequence. when you play back the sequence in sync with the DP-24, it repeats the actions you recorded.What is the technique for working without motorized faders?
