barefoot
barefootsound.com
Ok, at the risk of beating the dead horse into oblivion, I need to ask a slight twist on the perennial Mixing versus Mastering question.
I've been reading a lot about mastering recently and three points seem to ring out the most to me. Correct me if I'm wrong on any of these:
1. Don't master your own music. Have it done professionally because they have better equipment and a fresh set of ears.
2. Monitoring for mastering is different than monitoring for mixing. Mastering setups use broad frequency response speakers with wide dynamic range in extremely well tuned rooms with a minimum of acoustic obstructions in or near the sound path. Near fields are not suitable for mastering.
3. Get the most out of your mixes prior to mastering. You should try to get your mixes as close as possible to the finished sound. Theoretically the mastering engineer should just need to add the final polish to your tracks and shouldn't need to 'fix' anything.
Now the first point I have no problem with. I have no doubt that it's a very good idea to send your mixes out to be mastered by someone with a lot of experience, an outstanding setup, and a fresh perspective on your music.
Points 2 and 3, however, seem contradictory. If the whole point is what you hear in the end, and you want to try and get it as close as possible to it's final incarnation in the mixing stage, why in the world would you want to have a monitoring system which differs so dramatically from what mastering engineers use? From most everything that I have read, the wide flat responds and high dynamics of mastering systems (speakers, rooms, etc.) are designed to most universally "translate" to other systems (car, radio, home). They give the best vantage point to hear everything that's going on.
If this is true, then why is everyone using nearfields planted on their mixing consoles with loads of gear all around to reflect the sound? A mastering engineer would never consider doing this. Why should a recording engineer? Shouldn't we be pushing our systems as much as possible to resemble those used in mastering?
barefoot
barefoot
