miroslav
Cosmic Cowboy
No Coke, Pepsi....cheesburger, cheesburger, cheesburger, cheesburger...
https://www.youtube.com/watch?v=WH_b9XwloHE
Answer,,, digital is NOT superior to analog.............................. Also, analog in many ways is NOT superior to digital. Thread closed. This argument can not be won by either side because they both have advantages and disadvantages.
For example, most people probably didn't know that most converter ICs actually hit 0dBFS at 1-2VRMS. It's not complicated, really. . .
You are free to leave the thread if you like, but I don't see how your post is relevant to the continuing discussion. To the OP, this was a low-quality term paper. To most of the rest of us this an interchange, not an argument.
For example, most people probably didn't know that most converter ICs actually hit 0dBFS at 1-2VRMS. It's not complicated, really, the digital world standardized on supply rails a long time ago, and most converter ICs obey those standards because they have to communicate with the rest of the digital world. So their supply rails are typically +5VDC for analog and +5V or +3.3VDC for digital. If you have a +5VDC rail then you can't much exceed that as a peak-to-peak input. That's 1.7VRMS or so. Some chips hold their 0dBFS to within 2.8V peak to peak though, that's a nice clean 1VRMS. I don't think anybody goes beyond +6dBV as a max input.
So the whole discussion about digital headroom and operating levels is trying to fit new wine into old wineskins.
Let's look at mics. The maximum output a mic can produce is around +10dBV. That's a -30dBV/Pa mic at 134dBSPL; above that most mics would need an internal pad on their capsule to avoid distortion. That's going to need to be padded before any converter IC. Let's say -10dB. That yields a max level of 0dBV, add back +6dB of gain to clip our converter. We need analog headroom above that, let's say +10dBV. That requires a +/-5V supply rail. Hey, we already have a +5V rail for our converter! Just need that -5V now. Works out pretty well.
That yields an operating level right at -10dBV . . . a normal condenser mic at normal source levels would require a mere +20dB of gain; dynamics +40dB. How simple life could be . . .
Also agreed, and also a good point. I don't know if it's sad or humorous, or both, but it's something how the more one actually understands about the nuts and bots of this stuff, and the more one gets into gaming gain structure, the further (in concept, and more often than not in reality) one gets from the mythological "record as hot as you can" and "use all the bits" mentality that's still being fed to beginners like hormones to caged chickens.I also wanted to touch on the notion of not merely having "headroom" from operating level to clip point, but another 6 or 8 dB of "cushion" to make sure you not only don't clip, but stay in the best sounding operating range of the gear. Taking this seriously and consistently across the studio may cause you to decide that +4 dBu is too high of a level to do properly.
Which is exactly what I was trying to do, by using the +4dBu (aka 0VU in the signal path, aka a signal level of ~1.23v) level as a common base reference.Gents, it seems to me that the only way you can effectively compare analog and digital clipping / distortion levels across various analog and digital systems is by using volts.
A three word post. How refreshing.Digital is better.
Agreed, and this is a big area of weakness in analog recording . No matter how good it is, it cant match the dynamic range of a good digital recorder.This thought was not lost on the engineers when deciding how to calibrate converters. It's not a coincidence that as converter quality increases along with digital word length, that the dBu-to-dBFS calibration tends generally downward, starting back in the 90s with the -14dBFS EBU standard and the -15dBFS DAT calibrations, down through the -18s to the increasingly common -20s and even occasional -24s of today. The lower noise floors and increased digital dynamic range has allowed for the downturn in the calibration level, providing for more digital "headroom" above that reference without losing the lower volume dynamics to the digital noise floor.
This thread is full of hot air, .
I wouldn't say it's unreadable. I'd say it's got a lot of posts that are simply common knowledge that's been restated to try to sound intellectual.It's pretty much unreadable.
In certain circumstances, analog tape distortion/compression is a pleasing production effect. But it's still just an effect and a distortion.
This is the Big Irony IMHO and the crying shame of the trends of the digital age. One of digital's big selling points from the outset was the depth of clean dynamic range it offered, Even at 16-but it was/is usually significantly more than the total dynamic range of the analog signal being pumped into it.And besides...many people don't use the digital headroom anyway, they just push everything up to 0dBFS because they can. So in some ways, digital is its own worst enemy.
How much of that, though, is largely because that's what folks have become accustomed to, and not because it actually has an inherent pleasantness? Imagine a hypothetical planet where they, for whatever historical reason, tripped across digital recording before they did analog. They were used to digital for many years. Yeah it had gotten better as technology increased, but then someone came along with the idea of analog recording. Now, if analog recording truly intrinsically sounded better, there'd be no nostalgia for the "old school" digital sound, and digital would be dropped like lead balloon.True...but THAT may be the essence of why so many folks seem to prefer the sound of tape/analog VS. digital (without just looking/comparing their specs).
Well folks, the previous post pretty much wraps up this thread. Though, as a critique, it would have been more effective if the three superfluous words had been removed... value of brevity and all...
No doubt a following post will make this thread it WAY longer. But, none the less, at this point it's wrapped up.
After scanning parts of this endless wankthread I've decided that analog is superior to digital. For the simple reason that it's one letter shorter.
Umm... dude... you've got your forums mixed up. It's A and A that's the the "I wanna be a Gerg" place.But Gerg didn't say so.....![]()
