SonicAlbert
Super-Sonic "Herb" Albert
Is there any reason why you can't use digital zero as the reference, and line everything else up against that?
SonicAlbert said:Is there any reason why you can't use digital zero as the reference, and line everything else up against that?
Well, if I understand you correctly, it's because digital zero is not an absolute, nor does it lend itself well to displaying a common gain stage reference through the signal chain.SonicAlbert said:Is there any reason why you can't use digital zero as the reference, and line everything else up against that?
I agree 100%.masteringhouse said:I think the real question is how much headroom do you want to allow for?
That's your "reference level".
]. The K number is the amount of headroom you want/need for the application. When tracking you need to allow enough headroom for the dynamics of the tracks you are recording and -18 or -20 dBFS gives you bags of headroom for all but the most extremely peaky signals. It goes without saying that I think you should work with the same amount of headroom for all the tracks even though most won't use it.How would you adjust your digital headroom without recalibrating your converter(s)?iqi616 said:It goes without saying that I think you should work with the same amount of headroom for all the tracks even though most won't use it.
By controlling the level of the analogue signal I feed in. I use a Korg D1600 so direct calibration isn't an option - it is what it is.SouthSIDE Glen said:How would you adjust your digital headroom without recalibrating your converter(s)?
G.
Ah, OK, that makes sense.iqi616 said:By controlling the level of the analogue signal I feed in.
Farview said:The confusing thing is when you have all-in-one interfaces with no analog meters.
If they have digital meters, then all you have to do is check the maximum output spec, usually reated in dBu, subtract 4 and reverse the sign. That'll give you the +4dBu calabration level on the digital side.Farview said:The confusing thing is when you have all-in-one interfaces with no analog meters.
.iqi616 said:By controlling the level of the analogue signal I feed in. I use a Korg D1600 so direct calibration isn't an option - it is what it is.
I set the level either visually so that the average signal is somewhere around -18 dBFS (a guesstimate from the meter but a consistent guesstimate) or by ear - how loud the sound is coming out of my monitors when the volume knob is set to my standard operating level.
To change to a different headroom I would adjust my monitor levels and/or adjust the input trims and "target" a different average -dbFS.
That is assuming that it isn't a preamp built into an interface. The only output is digital, so there would not be an analog maximum output.SouthSIDE Glen said:If they have digital meters, then all you have to do is check the maximum output spec, usually reated in dBu, subtract 4 and reverse the sign. That'll give you the +4dBu calabration level on the digital side.
G.
Yeah, I should have said maximum analog level or maximum voltage level, not maximum output level. Freudian slip on my part. The wording changes from manufacturer to manufacturer, but as I understand it, the spec retains (for most gear) pretty much the same meaning; the maximum voltage level out of the analog stage equates to 0dBFS out of the digital stage (and vice versa?). So when a converter is spec'd with a maximum voltage of, say +24dBu, that would equate to a calibration of +4dBu = -20dBFS. Is there something I'm missing in that understanding?Farview said:That is assuming that it isn't a preamp built into an interface. The only output is digital, so there would not be an analog maximum output.
The Audio Cave said:Lots of good info here. I always assumed (and was told) that the 18dbfs reference level was written into an AES/EBU spec/document somewhere as an agreed upon standard for TV post.
masteringhouse said:Now, how come my mixes don't sound as loud as commercial CDs?
No. Higher resolutuion comes from more pixels. You want your audio to have as much resolution as possible, so you need to run it through a digital camera. I think MCI stopped making cameras, but Sony still makes good ones. You need one with AES/EBU or maybe Lightpipe. (Or some other kind of pipe.masteringhouse said:Should I change my reference level to -6 dBFS?
) Makes it sound more "optical"...
Nope, you have it right. My point was that you won't find a spec for just the analog side of an all-in-one unit. Like a Roland 2480 for example. The entire studio is one box. There are many newbs that don't realise that there is a separate preamp, converter, recorder and mixer in there and there are no specs to follow. Only the advice from the manual that tells you to 'record as hot as you can without clipping'. (Isn't that nice)SouthSIDE Glen said:So when a converter is spec'd with a maximum voltage of, say +24dBu, that would equate to a calibration of +4dBu = -20dBFS. Is there something I'm missing in that understanding?
G.
Well, some do have them. For example the Yamaha AW series does have "Max before Clip" specs for both the analog in and analog out, and in that case the "analog out" specs do indeed match the converter calibration.Farview said:My point was that you won't find a spec for just the analog side of an all-in-one unit. Like a Roland 2480 for example.
Agreed. I was never really questioning the validity of the -18 spec, just was looking to try and find an "official" handle with which to grab hold of the subject.Farview said:When I tell someone to average around -18dbfs, I pick that number because it seems to be an average of all the standards and a safe level for everyone.
Anyway, 2db in either direction won't make much difference.
Well, I occasionaly have questions of my own toomasteringhouse said:This is a very good discussion/topic. Good one G!
. Just soldiering on in the Internet S/N wars ... Yet another unfortunate case where both the industry rags and Wikiality - not to mention about a thousand other websites - provide (at best) misleading information.
