SouthSIDE Glen
independentrecording.net
Ok, I had it backwards; the video is from an analog source (VHS). It may be on DV now, but the the DV is really nothing more than a digital copy of the original VHS.Alexbt said:Video Source = Misc VHS, converted to MiniDV
Audio Source = CD/Album or new mix from source tracks (seems unnecessary)
The point of the project is to put out some kind of live-looking video (since the audio from the VHS tapes SUCK royally) to the audio of the album. It's impossible to actually shoot a video because the singer died.
So this is the next best thing... I'm pretty sure that it's possible to tap out the BPM of a song in order to vary the speed without changing pitch (a la DDR and other beat based games) but I don't know if that's possible with video as well. That's the kind of trick I'm going for.
Evrything I said in the previous post still applies, just that the caveats regarding playback stability now apply to the video and not the audio.
To answer your question more directly, yes it is very easy to stretch and shrink video in a good NLE such a Premiere or Vegas. You could simply mark, for example, the beginning and ending of a line or a verse or whatever in the song, match up the start point in the video (match up the initial drum hit, for example), and then one fashon or another drag the end of the video clip to correspond with the end of that audio section. Technically that's not an issue.
The point I was trying to make, however, is that you can't do that kind of "fitting" of the video to the audio for very long and expect much matching between what you see and what you hear. It's not going to be as easy and calculating the difference in tempo, because unnless you guys are as accurate as machines, the tempo varies slightly as the song plays, and never the same way twice. Plus, when was the last time the bassist related to the beat exactly the same way in two different performances of the song? On one he might play just ahead of the beat, the other just behind. You'll see that on the video. You'll see the drummer play a fill differently between the two performances, thevocalist using a different cadence, etc.; all the differences in performances between the beats as well as the variations in tempo will show up regardless of how you try and linearly line up speed of the video and audio playback.
Again, you can go thorugh the video and audio frame-by-frame and make fine-tune adjustments and such, and that works as well as it can. But chances ae you will never be able to disguise for very long that the audio and the video are two entirely different performances.
If you're OK with that level of quality (which is fine), then yes, the technical tools are readily available in any decent video NLE to do what you need to with both the audio and the video.
If, however, you are expecting to just speed up or slow down the audio and video in relation to each other by a calculated amount or amounts and expect them to look like they belong together for more than a few seconds at a time, you can expect to be disappointed.
G.
