Whoopysnorp
I had been working on a tune, and I had to leave for a few hours, so I closed everything and just let the computer sit. I don't run a screen saver, so not much was going on in the background while I was gone. When I got back, there was a blue screen error that said "Unable to write to disk in drive C. Data may be lost" or something similar. I had to manually shut the computer down (by holding in the power button), and when I tried to start it up again, it wouldn't go past the 'IBM Aptiva' screen it shows before it does all the bootup stuff. It won't load from a boot disk or CD, and I can't get into safe mode, or even the BIOS. What in the name of holy hell is going on?
(heavily modified) IBM Aptiva
700 Mhz Athlon in an Anigma S30 mobo (AMD750 chipset)
AOpen DVD-ROM drive (channel 2 slave)
Philips CD-RW drive (channel 1 slave)
1 20 GB HD (channel 1 master), 1 40 GB HD (channel 2 master)
352 MB RAM
TNT2 M64 video
SBLive Value
Delta 66
Linksys ethernet card
350W power
Win98SE
Also, I've been running with the case cover off for a while. Don't know if that would make a difference.
352 MB RAM
TNT2 M64 video
SBLive Value
Delta 66
350W power
Win98SE
