Which setting is better
heaven
Hi all, what do you think which setting is much appropriated?
a. Mic->Sanamps GT2->DMP3->Soundcard,
b. Mic->DMP3->Sanamps GT2->Soundcard
Also, after buying DMP3, I need to purchased additional cable. Actually, is it
have any sound difference or which one is better of a 1/4 TRS and a 1/4 TS cable? Which one is recommaned for recording?
Thanks.
Hey heaven - you should run the mic through the preamp (DMP3) first, and then to the effects box (GT2)...
For cables, the TRS cables allow for a balanced signal to be sent, but if any of your equipment does not have balanced in/out than the signal will not be balanced no matter what cable you use... the GT2 is not balanced as far as I know, so there isn't an advantage to TRS cables (either will work though).
