which microphone should I use on an upright bass?
  • Thread starter Thread starter rtzstudios
R
rtzstudios
Yes, yes I'm talking about those big ass basses!!!!Should I use a Sennheiser 421 or an EV RE-20? Or both?
If those are your only choices, try the RE20 in the "sweet spot", usually somewhere between the bridge and F-hole...
Other winners:
KM84 aimed at the bridge, about 6" away...
44BX in the sweet spot
EV55
EV635a in a pinch
Try running a DI with the pickup if the bass has one--add it to the mic signal for some definition...
LOL...
Actually my other choices would be a SM57, Shure Unidyne B, or a SCM 900, but I thought one of the others would probably be a better idea. Or am I wrong about that?
this last weekend i had a band in with the big guy.
i used two mics:
AT4033 LD Condenser
and a
AKG 460 SD Condenser (Cardioid Capsule)
i feel this turned out well. both mics were pointing just above the F hole, about 18" away, off axis about 20 degrees on the high freq side.
i panned both mics in the mix and this gave a great spaciousness that sat very well in the mix.
-kp-
I don't know which model, but most bands I've seen who have upright basses (and even cello) mount a small mic on the bridge.
I last saw Dave Brubeck 2 weeks ago and his bass player had one mounted on the bridge too. In the orchestra I play we mic the cello that way too. I'll check with the director once we go back...
An integral part of an upright bass' sound is the reflection off of a hard-surface floor, so make sure you don't mic up in a carpeted, damped room!
Bruce
I used a GT AM-52 in omni about 18" from the bass looking at the top of the right "f" hole. This was for a bluegrass band.
Thanks for all the replies! Also, I'm glad you brought that bit of info to my attention Bruce, I would have never known! :)
