I'm going to purchase a computer for mainly recording purposes, as none of the computers currently in the possession quite cut it. I will probably also use the computer for Uni. I've got a lot of options on the table at the moment, and I'm having trouble deciding, what do you think?
I record real instrument tracks rather than software instruments, I used to use Logic Pro but I recently switched to Pro Tools. My interface will probably be a Scarlett 18i20 by the time I buy this computer (unless someone here has something to say about that!)
I've considered the following:
Self-built PC
Macbook Pro
iMac
They all have their advantages and disadvantages.
Based on a little bit of research I have done so far, I think I need a fair bit of processing power RAM a soundcard and not much needed in the graphics area.
A self built PC is cheap, I can put one together for about $700. I can constantly upgrade it, and have the exact specs I need, including screen size. It loses out in portability-I.e using it for Uni, but Uni will only be this computer's secondary purpose, its practicality for recording comes first!
A Mac would be good to be able to revisit logic occaisionally, but I don't see this as extremely neccessary.
A Macbook pro would be great for uni, I'm not sure how well it would work with recording though. These are also much more expensive than a self built windows PC. I'm not sure what the specs are like, is it worth it? I generally prefer windows, but I have used Mac's just as much, and I wouldn't mind the switch too much.
An IMac has a larger screen size which would be good to have more plugins and mixers open at once, but once again this is an expensive option. It is also not portable, similar to a PC.
What do you think I should go with?
Thanks.
Self-built PC
Macbook Pro
iMac
Thanks.
