Which Computer Motherboard?
  • Thread starter Thread starter jgwilk
J
jgwilk
I have come upon a Mackie 1220 ONYX mixer with firewire card. I want to build an audio/recording only computer. I will incorporate the Mackie and probabbly have Acid Pro/Fruity Loops on the same computer. Can someone give me recommendations for the motherboard and RAM to use on this system? I would also appreciate input on hard drives and any other features I need to incorporate. I have been using Adobe Audition in the past, but do not know if it is usable with the Mackie. I will build the computer myself, but it has been a while since I built one and do not know what the latest and greatest is as far as audio goes. Thanks
whats your budget?
depends what your over-all goal is as well.. try and live on yesterdays technology.. will save you some money! for audio recording, and your needs.. a reasonable priced system these days (albeit getting out of date)
would be a Socket 478 Pentium 4 2.8 processor matched with any socket 478 asus board... one with built in firewire would be great as well.
As for harddrives, its recommended you record to a separate hard drive.. Parallele ATA drives theoretically tranfser data at 80megs/second .. this in most cases is fine, but for a little bit more, get a SATA-150 drive.. that much faster, and not that much more money.. (mother board must support SATA)
Its better to grow into your equipment, then to always be needing more.
As for Ram, again, this is all relative to the motherboard/processor combination you choose... a lot of people will try and push you into going the socket 775 route and sticking with DDR2 ram (newest) , but the gains are minimal from DDR to DDR2 .. hense why i suggested living in yesterdays technology.
Luckily, Acid Pro runs on beans. You could realistically get away 256 megs of ram, and a pentium 1.4 .. just make sure its clean, and only used for studio purposes.. close all other applications while doing recording.. i believe Acid can only track one track at a time though?
Anyways, post up some questions, and ill see if i remmeber to ge tback to you :)
Well.... I just bought a rackmount case, but I'm trying to decide on the MB and processor myself....Me n you are in the same boat.
If you go Pent 775, then make certain to select Intel chipset on the MB.
If you go AMD 64 socket 754, then I would suggest this MB:
http://www.epox.com/USA/product.asp?id=EP-8KDA3plus.
Cause it has the nForce 3 250 chipset...
You can get a pretty decent price with Tigerdirect's bundled board/processor packages.
I ain't looked at the AMD 939's due to cost considerations....Same for the dual core AMD stuff...I don't want to spend that much.
Either way, my board needs 4-5 open PCI slots and AGP for my ATI 9200 dual video card and 1 meg of compatable RAM.
Try a google search using keywords, "Build DAW"...you will get lots of good info that way and see many examples of home built DAW's....Just make sure to look at the date on the returns...you want a build that is as recent as possible and includes the latest info/selection.
Well for audio stuff you Luckilly don"t need to have a Monster Machine to get Good Performance....
I was Getting sick of Haveing to Pack up my PC and takeing out to my Studio ever time I wanted to make Music so I decided to get a PC Dedicated to music recording....I looked on E-Bay for a couple weeks and was eventually able to get a New P-4 2.6ghz with 512mb DDR and a 60GB HD and a DVD/CD-RW Drive for $180 US Pluss shipping and this system works Just as well for recording as My other system that is a 3.2ghz with 1gb DDR and 320gb HD....
So you really don"t have to spend a Lot of Money or get the Fastest system in the world to Record Music.....
Cheers
I built my pc. I am rebuilding my pc.
Most important to me NOW (after building).... BUILD around "quiet" parts.
www.silentpcreview.com <-- very good site with messaage board
www.endpcnoise.com <-- where you can purchase quiet pc parts.
There are some others too but i forget. SilentPCReview is really good though. My machine is fairly quiet at first "hear" but when your sittin next to it for longer then 5 minutes you begin to hear these turbo engine fans with loud vibrating aluminum case etc. And I took a lot of measures to quiet it down and its like a lost cause I just simply bought a loud case. Obviously I didn't do enough research.
There are cases designed to be very quiet plus absorb noise. Go with Antec for your case is my best suggestion! You can always also build a nice wood case to surround for your computer case and line it with foam to help even absorb MORE noise. Thats what I'm doing. As with a rack mounted case I dont really seeing that happening. See I need my stuff to look good and run good. Now I learned I needed it to be quiet and cool. Hense "rebuilding my computer"...
The antec P150 is a great case but has a faulty powersupply in most cases. (been reported all over the net. but antec will send you a new one people have been saying.) Plus you could always purchase a new powersupply as well.
http://www.antec.com/us/productDetails.php?ProdID=81500
See first I wanted to build a "cool" pc with some lights etc. I did but it's too loud...
The absolute best case for building a silent (or quiet) pc is supposedly the ( http://www.antec.com/us/productDetails.php?ProdID=81800 ) Antec P180. I would go with the P150 personally but its white. I want black. I'm going with the next best thing. The Sonata 2 ( http://www.antec.com/us/productDetails.php?ProdID=15139 ). The sonata aint the prettiest but it does what its suppose to.
Definitely build a "good" pc with good parts. But don't ignore the quiet factor. I made that mistake. I also did not get parts that were listed as combatible. (never knew to check). Make sure your motherboard and video card are listed as combatible. Thats what I have had the BIGGGGEST issues with.
Other then that take everyones advice from here and silentpcreview.com. Everyone can help you build a powerful quiet pc.
I mean I been through all this and I'm stuck between the P180 and the Sonata 2 by antec. There is a company that actually makes precut foam for the inside of the sonata & sonata 2 (the p150 comes prefabricated with foam for insluating ) so I forsure am insulating the inside.
Biggest thing I've learned is dont do a case with a top or side fan! You want air in the front and out the back. Its the quietest and easiest. PLUSSS you want a 120mm fan on the back for sure! Cooling is a factor for sureee... They sell very silent ones... do your research at silentpcreview.com. You'll find lots of info.
Do NOT go with celeron procesors. I went with a 3.2 celeron with 1gig of 133 ram and a $35 motherboard from axper. STAY AWAY FROM AXPER! Its some company based in like china that has NO support! My computer isnt so slow, its fast, just not fast enough for an impatient person like me. I had a 1.7 athlon processor with the same gig of ram and it was speedy. I was ok with it. That boggles me but i guess thats the difference.
Athlon and Intel does not have the same speed measurements. So a pentium 3.2 will be different then a athlon 3.2 as I demonstrated.
Thats all I have to say really. So lets recap. haha.
You need to consider these factors when building a computer. Building it quiet, powerful, and keeping it cool. Oh also, don't sacrafice on powersupply as people will tell you. Powersupplys are probably one of the loudest components so check endpcnoise.com and silentpcreview.com.
YESSSSIRRRR
Hope you appreciate my long rambling post. haha. It's what I've learned form my first build. The more research = the less money wasted on purchasing wrong stuff and having to learn the hard way.
Thanks
Thanks to everyone for their replies..I guess I should have said my budget is rather limited. You all gave me some good ideas and information to research.
It has been so long since I dealt with all of this and it can be mind boggling.
Thanks again
