H
hubb_99
i have a couple of behringer stereo compressors/gates, i would like to mainly be able to use them as gates to cut out some of the noise, eliminating peaks and for mild compression. my setup is a mackie 1604 out of the channel inserts going to a delta 1010. i am a little uncertain how i should hook up these comps.
don't i want a compressor to be pretty much right after the preamp?
would i want to go to the channel insert to compressor then to the delta?
or is there a better location
