D
darkecho
say (on a 100 point scale) 40 degrees to the left, is ALL of that sound wave going to be contained within the space between 39 and 41?
or is 40 where the center of a wider sound goes?
for instance, if you have a mono track at 0 and its sounds extends 3 degrees both direction (so its audible range is -3 to +3; and centered at 0) and pan that signal all the way to the right(+100) are you going to be cutting off half(or whatever amount) of that signal because it can only go to 100 and the midpoint of that signal is at 100, thus you have its range from 97-103 but cannot go past 100 so you lose the other half?
this probably sounds very confusing... i guess how much space does a given sound take up on the spectrum of possible panning positions?
cause if what I said was true and a given sound extends 3 degrees in either direction from the mid point, then if you put it at 100 (and 100 is the mid point) you wont be able to go to 103, so you would have only 97-100, not 97-103...
is this making any sense to anyone?
