Im serious when I say, dont use it unless you have to. It boosts up the volume of everything and has a tendency to boost distortion, background noise, clipping, all the things you dont want to hear. Let your recording "almost peak". Digital audio is different than analog. With analog "let the needle just hit the red", thats NOT the same case with digital. But yes it is ...well, almost. I record as loud as I can without "clipping" in digital terms, thats hitting "0" on the spectrum. Past "0" makes an a very undesired, unpleasent loud "pop" sound. I usually keep it around 4-5 dB. Then what volume I cant get from that level, Ill use the "loudness Maximizer."
I've probably off the type of my head have made over 200 recordings, just on Cubase VST alone, and 300-400 total, including analog recordings.
It also has to do with the way you get your signal into your sound card. For example, heres a list of the equipment youll find at my studio Crystal Blue Productions:
COMPUTER:
1st Computer: Pentium-3 500,256 Meg RAM,7200RPM 4.3G UIDE HD
7200RPM 4.5 SCSI HD, 4 Meg Video,
D-Man PCI Audio card, 17" Gateway Monitor
2nd Computer: AMD K6 3-450, 192 Meg RAM, 16 MEG V00D00 3d
Video Card, 4 Meg video capture Card
(for video editing), 12X CD ROM,
Memorex4X4X20 CDR/RW, 17" Voxon SVGA Monitor
SOFTWARE:
Cubase VST 3.71r2
Soundiver
Steinbergs Clean
Steinbergs Recycle
Acid
Soundforge
STUDIO EQUIPMENT:
Sony 4x4x20 CD-R/RW
Fisher Dual Cassette (Mixdown Deck)
Sony Stereo Mic
Tascam TM-D1000 16 Channel Dig Mixer (vocals mostly)
Event 20/20 Nearfield Monitors
Haffler 50W/Channel Amp
Unitor8 MIDI patch bay
Alesis 32 Band Graphic steeo EQ
Alesis Nano Compressor
Mackie 1202 (For Mixing Modules, Keyboards and samplers)
Roland S-330 Sampler (W/External Video mon.and Rem.control)
Roland JV-1080 (Dance card,Tekno card, 2100 other patches)
Roland D-110 Sound Module
Roland U-110 Sound Module
Akai s2800 Sampler
Yamaha TX81Z Sound Module
Yamaha FB-01 Sound Module
Alesis DM5 Drum Module
Roland JW-50 as a Master Controller
If you have any questions, post a message here or Email me at Downtownsounds@aol.com
