I know where the magic button is. Does anyone else? wink....
I'd suggest aiming to cut where possible rather than distort by pushing up to hard
Steven Slate said:"Don't be a pussy with EQ". There is no right and wrong.. only "sounds good" and "sounds like ass". Whatever it takes to get to the first one, do it.
Put another way, if you add 6dB of boost to a signal that's already peaking at -6dBFS (far from unheard of) at least one frequency on that track can hit 0dBFS which gets you into the realm of clipping. Or, probably more realistic, if you've got 6dB of boost on a particular frequency, then decide to push the fader up a bit on the whole track, it's easy to miss the fact that just that single frequency hits clipping while the rest of the track is still at -6dBFS. Even meters can often miss this depending on how they analyse the signal.
This doesn't make it a hard and fast rule against adding EQ boost--it just means it's something you have to be careful about.
I prefer filters to EQ there for most cases, but if you cut with EQ, then it is likely to cut stronger.
hey prehistoric dog .. like your music.Eqs are filters.
May be more realistic, if you have a particular frequency boost of 6dB, and then decided to push up the fader on the whole track, it is easy to miss the fact, only a single frequency Click to cutting, the rest of the track is still in 6dBFS.
Me no understand
Spambots used to post sig line spam I can almost understand...Spambots that just post random phrases have always puzzled me.
