When double micing
  • Thread starter Thread starter Omniscient
O
Omniscient
I just started double micing my stuff and I found the spots for the mics that sound the best. So when I'm at the mixing console and sequencer, do I record both mics to one audio channel? Or do I record them to their own channels?
Well I'm a newbie here too, but if it were me I'd do it to two seperate channels. This way you can play with volume/EQ/panning/effects/whatever with each mic'd sound individually. This could allow you to add depth and space to your instrument in the mix. The only benefit to recording to one channel would be that you'd be saving space on the hard disk (I think, could be wrong) So I'd say that if hard disk space isn't that precious to you, then definitely do it to two channels. If you find you're not gonna tweak each one differently, but either leave them alone or apply all the same tweaking to both, then you could always just bounce them to one track anyway. I've got hardly any equipment and I wish I could do two mics to two channels from the source at the same time. It's also a preference thing, but you'll definitely have more options using two channels.
Again, I'm new and learning as well, so if anyone reads and I'm wrong, correct me.
If you really like the sound, you can mix them to one track. I used to do this in the old days when track count was limited. Now I don't because I like having the flexability.
When double-miking I generally mix to one channel. I do this because once I am happy with the sound I am content to leave it at that and because if there is a need for editing the part, it is easier to edit one wave than two.
