Joan, you probably should have started your own new thread here. We're answering 2 questions here. 1. When do you need a preamp? and 2. What do *you* need to record spoken words?
1. You need a mic preamp anytime you use a microphone. Harvey, of course, boiled it down to the bare essentials. In the real world, the signal of a mic is never strong enough to be recorded without its gain being increased. There is a third case where a preamp should be added- when the next part of the signal chain that would raise the gain (usually the built-in preamp
in your soundcard or Digital Audio Workstation) introduces undesireable sounds (noise, distortion etc.) or eliminates or modifies good sounds, rendering an incomplete or inaccurate result, and needs to be bypassed. The tough part here is that what is desireable or undesireable is a matter of opinion. Some kinds of distortion may be good, and deleting some sounds might make Pee Wee Herman sound like James Earl Jones. If your mic is recording something, you already have a preamp, the only question is, is it doing what you want it to?
2. Joan, I'd say your mission is essentially simple, and many big time music recording people here really can't help but think in terms of their often more complex needs. I would say, get a good soundcard, as Tex suggested, get the best 20 foot mic cable you can find (Mogami, Monster, or B.L.U.E., among others), and that SM58. Isolation means put that microphone where the computer isn't, such as on the other side of a door, and point it away from the computer, or put something big, thick, fluffy and heavy between the computer and the mic, even a pile of laundry will help. That good soundcard will contain a preamp, which may or not be adequate for your needs. Plug that Shure right into the sound card, and see if you like the results. If not, consider an outboard preamp, but for your purposes, a good soundcard will probably be all you need. If you really need a de-esser, it is available as a software plugin, if the sound card doesn't provide it. You will also need a pop filter, a nylon screen between you and the mic, to decrease unwanted sounds from your breath with consonants like P and B. Just put your hand in front of your mouth and say any word with a P in it, and the reasons will become clear. Yes, this is technobabble, but it will get easier. Just don't read any of the threads on MS micing unless you've got your Tylenol handy. Hope this helps.-Richie
