DeathKnell
Hi there, i just have a quick question.. I'll use these tabs as an example.
http://www.e-chords.com/cifra.asp?idMusica=16076&keyb=true&aba=2
(Down So Long by Jewel)
If you scroll down to the bottom you can see all the chords used, however.. I still don't understand the logic behind chords i've come accross with the / between them.
(in this case the C/B and the Am/G)
From what I gather.. the 2nd letter indicates the starting note.. however is it normal to change the voicing of the initial chord (without indicating in the chord name) like has been done in this? it doesn't appear to any sort of inversion that i have come accross so far and has thus confused me.
Basically, if i dont have the sheet music to double check... what should i presume is implied by chords with the / between them...
thanks..
thanks..
