I'm very new to the world of home recording but I'm interested in learning more about it. I've used GB when recording scratch tracks of riff ideas and has seen Cubase being used once or twice when recording multiple tracks during live shows and practice sessions on a laptop. I'm considering PT because I hear it's the industry standard for DAW software but I've also heard great things about Logic Pro and think it may be easier to learn since I've use GB from time to time. I'm interested to hear any ones thoughts about either. I'm also interested in hearing any advise or comments about audio interfaces. I've just purchase a M-Audio Fast Tack that I'm playing around with. I would be interested to knowing what thoughts anyone has about multichannel audio interfaces and which brands and models you'd recommend.
First, I would say, don't buy something ONLY on the strength that you've been told it's "Industry Standard". This is a very wide term and should be taken with a large pinch of salt. The most basic description of a DAW can be summed up as being merely a landing and connecting space for sound files and VST plugins. Then it has a range of virtual input/output paths to your hardware and various routing possibilities within. Then it has to be a stable piece of software, with efficient memory use. Most, if not all of the mid-priced DAWs out there should fit this criteria, to a greater or lesser degree.
The most probable reason for anything to be termed 'Industry Standard' is the fact it's used in the industry. A LOT of things are used in industry - and when things DO get widely used, there comes a dependance on compatibility by it's users. Professionals want to be able to work together without such issues getting in the way. When someone has been trained from the start, exposed to a certain 'standard' of software, it's generally what they'll use at home and also recommend to beginners. You might find with Pro Tools, you're paying for features and options you may never use. On the other hand, many professional musicans have been known to use Reason, Logic,
Garageband and FL Studio for putting tracks together initially in their own time. For instance, Mike Oldfield uses Fruity Loops (for establishing the basics).
So my advice is to start out with something virtually free, such as Reaper and decide then what you want out of a DAW, based on your experience.
Also you can download demo versions of all the major mid-priced DAWs so you can try them. I personally recommend FL Studio because it's chocked full of VST instruments and effects - but again, try before you buy.
Basically, I think, if you don't know why you want to use something, other than it's 'Industry Standard' label, then you are not ready to buy anything yet. Do some research and download some demos to 'try before you buy'. Look for something that suits YOU, not something to impress your mates with.
