P
pure.fusion
Hi all,
Just struggling with the basic fact that after you mic something up, it's just not the same during play back as it is in real life. That's what mics do - even the good ones.
Specifically, I'm having trouble with guitar amps and mild distortion. I've been dialing up a clean sound in my amp (low wattage, 12" speaker, open back cab) and then pushing the gain up 'till I have a beautiful even smooth constant overdrive. We're not talking death metal buzz here, just a smooth fusion-y gain. This valve produced sound is just fantastic to the ears and life can't be better, birds are singing, the world's a wonderful place.
So you get your sm57 and close mic it up. Doesn't matter if it on the grill, or 6" away, off axis, on axis, centre cone, edge of cone, the resultant recording sounds quite different to the source, with specific attention to the amount of gain. The recording sounds a lot cleaner than the amp does in real life.
Granted, the result is a fantastic "clean" sound that valve amps are famous for but it's still not what we were listening to originally.
So, (Naturally) you turn up the gain on your amp thinking that obviously if the recording process dulls the amount of gain and we should begin the process by having more. So sounding a bit more distorted than you like, you hit the record button and what goes down is again quite different to what you hear, but in a different way.
So, to try and take the mystery out of it I've also looked into mic blending, room micing, recording at different volumes, different rooms, different position in rooms - and a whole bunch of other stuff.
Having learned a lot along the way, I still am struggling with the fact that What you hear is not what you get.
Am I not alone with this problem?
And should I continue to try to capture the sound sound that I hear through my amp? (As opposed to perhaps making sound choices some other way involving mic's and headphones)
Cheers,
FM
Cheers,
FM
