Yes I was just making a joke. But I'm curious, if the thickness of the oil will make the unit work harder. Just wondering.
I know you were making a joke, but joke or not you landed on the bullseye anyway
Yes, the thicker the oil the "more power" is required to start movement as well as maintain it. That's why cars nowadays use 5W30 instead of 10W40 - thinner oil offers less resistance to moving parts so cars of today can get better mileage - less oil resistance.
In the old days thicker oil was necessary to compensate for car maker's inability to mass produce moving parts with any kind of real precision - the former 10W40 compensated for that.
For this very same reason, as your car accumulates mileage you should be changing oil weights. For example, my '93 F350 crewcab requires 5W30, as do most vehicles of that era. At about 250K miles, I changed to 10W40 to compensate for the years of engine wear. When I hit about 400K miles, I switched to 15W40, and have been using that since. I have a little over 500K on it now.
In the worst NJ winters where the temps go below freezing, the truck doesn't start up instantly and has to crank a bit because 15W40 is a fairly thick oil. But if I don't put in 15W40 at this point the truck will smoke a bit when I first start it, for about 30 seconds or so. If I were to put the 5W30 in at this point, it would smoke for about 5-6 minutes then stop. 500K miles of engine wear makes for larger clearances in all the moving parts and that's why I use a thicker oil - to compensate a bit.
Obviously if I keep driving this truck I'll need to rebuild the engine... and we're getting close to that point actually.
Anyway, the same applies to tape deck motors - the thicker the oil the more power is necessary to start movement as well as maintain it - however quality tape deck motors (such as in the higher end decks) you will find either ball bearings or bronze bearings - which allow for easier starting than steel bearings which is what automotive engines have.
Bronze bearings are just a bushing - a round collar - but because Bronze retains oils in it's porous surface the oil itself is the bearing. Thicker oils "stick" better in this case. For ball bearings, the thickness of the oil doens't matter that much as the design of the bearing makes it easier to start off regardless of what oil is used.
In the latter two cases, a thicker oil will be retained by these bearings longer when not in use - so that is why I prefer to use gear oil in professional grade decks - not because it's thicker, but because it clings better.
Consumer cassette decks didn't use oil at all and instead used a lithium grease, which is far thicker than any oil. The little motors in consumer decks could start the mechanism just fine, right? Push play, hear music. They used grease because 99.9% of the consumers aren't going to take their $49.95 cassette deck apart every so often and re-lubricate all the moving parts - they just throw them out every 3-10 years depending on use.
The problem with grease (and deck motors) is not that it's thicker per se, but that it's stickier. Any dust and dirt circulating in the air will circulate through the consumer casette deck as well and some of that will land on the grease, never to be released. That dust and dirt adds friction, and after enough accumulates, the heads and capsan rollers no longer move forward easily, and the deck motors will be slow to start. Eventually, it will gum up and "sieze". Then you toss it.
This is why consumer casette decks didn't really last a long time in the homes of a smoker - the tar and smoke particles got into the grease and formed essentially a glue.
Temperature has a lot to do with oil viscosity, but I didn't go into it since it's unlikely that anyone is going to operate a professional deck outside in the snow.
