What Time Signature is this song?
Tadpui
When I count it out, it sounds like a plan old 4/4. The intro drumsticks count out 3, the very first note is on the 4th beat. Then 4/4 works out evenly from there on.
4
4tracker
Guest
Hm, thanks.
To me the main riff (A-G-E) sounds and feels like 3/4. I try to tap 4/4 to it and can't play it on guitar. The opening riff (the slide from F-G) doesn't sound like 4/4 to me, either, but I can't figure out what it is. The rest I can count in 4/4, though it doesn't "feel" exactly right to me not sure why.
rob aylestone
Managed 45 secs. Solid 4/4 throughout.just interesting gaps and emphasis. Just count the into two three four and you are in and locked!
Greg_L
Banned
LOL 4/4. If there is something weird in there I'm not hearing it. You can steady tap 1-2-3-4 easily through the whole thing. Well, I can. You obviously can't. Keep trying. A lot of things happen on the "ands" and turned around beats. Don't let it throw you off.
fat_fleet
Swollen Member
Also, how does a non drummer figure out the time signature?
Take a basic level music class.
Luckily I grew up before school arts budgets were slashed and had music classes that covered beats and measures in.. I want to say 2nd or 3rd grade?
fat_fleet
Swollen Member
Drummers please!?
Also, time signatures are equally important for all instruments.. so if you're serious about learning music, you might consider some intro lessons or a class like I mentioned.
CMolena
Yeah the offbeat can make ir confusing. I thought that they were cutting one beat, but I listened closely and is definately 4/4.
Dont worry, though, music is much more "feeling" than "knowledge", at least in my opinion.
sheboygandrums
4tracker,
Great energy in this song. It's all 4/4. No 3/4, but a few reasons the time signature sounds more complicated than it is.
1. Beat anticipation. The A-G-E riff anticipates beat 1 by starting on the & of 4 of the previous measure. This is a common figure in pop and rock music. Usually it doesn't bother us. In this song, combined with #2 and #5, below, it gives us the impression of 7/8 time when the riff starts.
2. Chord progressions we're used to hearing on certain beats. For example, the E of the A-G-E riff is on 3. We're used to it being on 1. Plus, see #1 above.
3. Rhythms we're used to hearing on certain beats. For example, in verse Riff A, the A-A with the snare drum is on 2,3. We're more comfortable with it on 4,1.
4. Inconsistent phrase lengths. The verses have 3-bar phrases, then a 4-bar phrase. The post-chorus is a 6-bar phrase. Other phrases are 2, 4, 8 bars.
5. Fast tempo. It all happens quickly so it's hard to process when unexpected things happen.
6. All-around rowdiness.
For Programming
Quarter note = 186 bpm
0:00 Measure 1 (count-off and pickup notes)
0:02 Measure 2-5 INTRO
0:07 Measure 6-13 PRE-VERSE Riff B (Instrumental)
0:18 Measure 14-21 PRE-VERSE Riff A (Intro)
0:28 Measure 22-29 PRE-VERSE (4-bar phrases) yeah...
0:38 Measure 30-44 VERSE 1 (3x3-bar phrases, 1x4-bar phrase, 1x2-bar)
0:58 Measure 45-52 CHORUS
1:08 Measure 53-58 POST-CHORUS
1:17 Measure 59-62 PRE-VERSE Riff B
1:22 Measure 63-66 PRE-VERSE Riff A
1:27 Measure 67-74 PRE-VERSE
1:37 Measure 75-82 VERSE 2
1:57 Measure 83-90 CHORUS
2:08 Measure 91-98 POST-CHORUS
ETC.
Contrary to what was previously suggested, the count off is 1,2,3, with the entrance (pickup notes) on the & of 3, and & of 4.
For programming, you may find it useful to use a transcribing program to slowdown and repeat sections of the song. You may find free ones, but this is the best I've found and I use it for my professional transcribing jobs: SeventhString Transcribe!
How Does A Non-Drummer Figure Out A Time Signature
It's been suggested already: count along. For this song, it helps to tap your foot. The key is to count at a consistent rate; don't count some numbers slow and others fast. At the beginning of the riff, start counting from 1. When the riff feels like it's restarting, start over at 1. It may take a few attempts, but eventually you should get it. There's more than one right answer. For this song, I agree that 4/4 is the most reasonable time signature, but every music can be written more than one way. This song could be written as 2/2 or 8/8 with identical notation as the 4/4 at 186 bpm. It could also be written as 4/4 at 93 bpm, in which case note values would be halved, so you'd write 16th notes instead of 8ths, and 32nd notes instead of 16ths. There would be half as many measures in the song. The 3-bar phrases referenced above would be written as one bar of 6/4, or a bar of 4/4 followed by a bar of 2/4, or 3 bars of 2/4.
– Jamison
Robus
Plain old 4/4. Some of the changes are happening on the "and" of the 4. And, their timing is...well, relaxed. Don't let it throw you.
I love that album!
