One other little piece of advise I offer a newcomer to home recording that I came across myself. With a 4 track, when you bounce tracks (say 1,2&3 to track 4) after you've finally and carefully balanced the tracks to get your 1 combined track, always clear tracks 1,2 &3 before you reuse them (ie put tracks 1,2 &3 in RECORD and make a complete pass before you reuse them). Reason; If you don't, you might produce (from punching in & out) "remnants" of your old tracks which, while they are still part of the song and will blend in, the difference in volume between the bounced track and the remnant will produce an undesireable jump in volume for however long the remnant is. I don't know if I've explained this very clearly, but trust me on this, not clearing your previously used pre-bounced tracks will produce an effect that I assure you, you will find undesireable.
Voclizr
