zero260
Hey All...
I have been reading this forum for quite awhile for entertainment as well as education. There are a lot of very knowledgable people here so hopefully this will have a simple answer...
Basically I've been using Acid & Cool Edit Pro for nearly three years just to throw ideas down and would have a "rough mix" to take to the "real studio". So lately I've decided I'll try to better my setup at home and try to achieve a satisfactory "semi-pro" sounding recording from home. Instead of forking money over at the studio, put the same money into MY OWN studio.
So I've revamped my room, upgraded my PC, and bought SONAR 3. I have been comfortable with CEP, but after reading this forum this seems like it's a better step towards "moving-up".
Anyway, on to my question.
I have been researching this forum to help me make up my mind regarding what sound card or audio interface I should get. I already have a Mackie 1604-VLZ Pro mixer so I don't think I need to get something like MOTU or whatever else having mic preamps and 1/4" inputs since I have this already with the Mackie. I'm thinking I can buy a decent soundcard that can hook directly to my Mackie and get similar if not better results than purchasing an Echo or MOTU or what-have-you. Am i correct in thinking this? Am I correct in thinking, "Why should I buy a $500 - $700 audio interface when all I need is this $250 sound card and my mackie?"
Now... What card would you recommend?
I have a:
1.2G
512M Memory
WinXP Professional
I think I would be satisfied with the ability to record two tracks at once... but obviously 4 would be better and 8 would be outstanding.
Hopefully this is enough info. If not let me know. I'd appreciate your thoughts.
Also, side question... is the sound quality from CEP comparible to SONAR 3? My take from reading the forums is that CEP is the underdog and SONAR is king. I know it will vary from person to person, and the 'ol "use what YOU know and YOU like." But if I liked Windows Sound Recorder I would hope someone would say, "Hey... It's time to upgrade, buddy!"
My reason for asking, I want to know the end result of learning a new tool is going to be justified. I really don't want to spend time getting use to a new program if the results are going to be the same, or barely different than my Cool Edit Pro.
Thanks guys for your time and input. I look forward to the replies.
-Tony
I have a:
1.2G
512M Memory
WinXP Professional
My reason for asking, I want to know the end result of learning a new tool is going to be justified. I really don't want to spend time getting use to a new program if the results are going to be the same, or barely different than my Cool Edit Pro.Thanks guys for your time and input. I look forward to the replies.
-Tony
