cominginsecond:
Oh boy! You like Larry Crane's work, you dispute what I am saying here, you offer NO other alternative to it, then you want me to explain to you why I don't like Larry Crane's work?
I think I will just let me words stand.
Sigh...............
crossstudio:
I could shoot you for opening up this can of worms damnit!!!
Predicted next questions:
1 - What is an L1?
2 - What does it do?
3 - What general setting should I start off with?
4 - I make everything louder, but the songs between themselves still sound unbalanced. What am I doing wrong?
5 - After I use the L1, the CD's when I play them on a stereo system sound totally flat and lifeless. What am I doing wrong?
Oh well. Let the questions start. We haven't had all the "volume matching" with plugin's questions for what? 2 weeks now?
Okay. sonusman feels VERY generous tonight Landie. Piss me off enough, I start talking!!!
Waves (
http://www.waves.com) makes a nice littel diddy of a plugin called the L1 Ultra Maximizer (no shit, that is it's name!!!) But it or find a cracked version ( I officially do not endorse nor condone software pirating...I HAVE to throw that in you know....
). Install it to your favorite .wav editing program like Wavelab or Sound Forge (actually, Waves plugins usually have their own installer program, so you just run that and your editor will find it next time you open it....)
Pull up your loudest song you have. Apply the L1 to it. The main control you will be dealing with is the INPUT control. How you use it is to LOWER the input control. By doing this, you RAISE the input on this unit. Cool eh? Nice and confusing, but not really.
Okay, what you want to be checking for it how much Gain Reduction is happening. I don't really recommend that you have any more than 6dB MAX gain reduction on the L1. Anything more than that and you start really killing transients in the music, and your resulting file will sound flat and lifeless. You can view the Gain Reduction via the Gain Reduction Meters on the right side of the plugin interface. There is a number that is displayed at the top of the meters that shows what the highest amount of gain reduction it did on the song. It is a good idea to "clear" that number every time you play the song when you are experiementing with Input settings because it doesn't clear itself. So say that you applied to much Gain Reduction on one pass of the song, but you made an adjustment, if you don't clear that "Peak Hold" number for the Gain Reduction Meters, you won't be able to tell if your new adjustment is within the parameters of what you want. So clear the Peak Hold every time you restart the song.
So, you have the first song as loud as you can go with it. Cool! You are the main mastering man now!!!!
Apply the plugin to the .wav file and save a new version of the .wav file. DON'T overwrite the original .wav file because you may want to go back at some point and use some different settings and you wouldn't be able to if your overwrite the "non mastered" version of the mix right? (sorry, some people do silly things like this...so I thought I might at least cover this....if you already thought of that...please excuse....)
Open up another song. Raise the input again until you are getting around 4-6dB of Gain Reduction. Apply that to the .wav. Now, COMPARE your first "test .wav" file with the next one. Do they sound about the same volume? If not, then you need to make some decisions. If the new mix is still quieter than the first one you processed, you can try raising the input on the L1 some more. But, by doing this, you of course will have MORE GAIN REDUCTION than 4-6dB. It may or may not sound okay doing that. If it does, cool. Raise away you mastering phreak you!!! If it starts sounding kind of shitty with more Input Gain before you can get the second song as loud as the first, well, there is another problem. More than likely, the two mixes probably sound fundamentaly different in the frequency response. Well, you can go and try to fix that too!!! But, now we start getting into very dangerous ground!!! Yikes, you would be starting to do what REAL mastering engineers do. And since you don't want to do REAL MASTERING (as per your original post...stated there that is....), then we are just sort of matching levels up here, and getting a bit more gain out of mixes. So, you might have made the first mix too loud. Yes, the first mix COULD get that much louder for any number of reasons, but the second CAN'T. You may need to go back and not have the first mix quite so loud.
So, you do this same process with all the songs you want on the same CD. I recommend that you compare them all to the very first "loud" song you "mastered" (so to speak...). After you feel they are all about the same, you can compare them to each other. Even after big time professional mastering, songs on a CD are NOT going to all sound the same relative volume. And thank God for that!!! That would be fatiqueing to your ears to listen to. Oh wait!!! Crap, Everclear does that, so you COULD make them all loud as hell. ......
But, if you IMPROVED the relation to each song concerning volume between them, well then, you did good!!! So, at first, don't sweat trying to be Bob Ludwig and just get through the process. I am sure you will be back with MANY questions when you are though. Or maybe not. Who knows.
Again, I will warn you that "mastering" limiters (like the L1) are VERY easy to overuse on a mix. Most people do not have monitoring systems with nearly enough headroom to hear the bad artifacts, nor the experience to hear the tell tale signs of over compression/limiting. At first, you will be going "Gee whiz, that is cool" with this stuff. But, after a time, you will sober a bit, and realise that overusing these kinds of devices makes a mess out of your music. You lose dynamics, and in really bad case scenarios, the sonic integrity can be compromised for the worse.
I can tell you that if you are mixing your songs, you have a better opportunity to do the RIGHT things WHILE mixing them to assure that you don't have to overcompress/limit during mastering! A few things to look out for.
1 - Too much low mids in your overall mix. Kick drums and Bass guitars are the worse offenders, but keyboards can murder the low mids too! Keep an eye on your low mids while mixing.
2 - Keep in mind that your room, unless you had it designed to be acoustically balanced, will make you THINK you need more low end in your mixes, when if fact, the "just right" amount usually sounds like too little. There are many factors at play here. It is a good idea to periodically do a mix, and take it to another sound system to play it on so you can get an idea of how the mix sounds in the "real world" of people listening. Car stereo's work fine for this.
3 - You HAVE to learn HOW your studio monitors sound!!! Yes, they may be MOSTLY accurate, but usually not totally accurate, and being accurate isn't what is the most important thing that I am talking about. You have to know what a good sounding mix sounds like through studio monitors. Your mix HAS to sound good on consumer playback systems. Studio monitors are NOT consumer playback systems. Studio monitors allow you to hear what EXACTLY is going on in the sound. It may sound like garbage on your studio monitors to you, but great on consumer playback systems. Don't believe me? Try playing some professional CD's through your studio monitors. If THEY sound a bit odd too, you will then know what I mean. So, you need to learn HOW your monitors sound on a good mix. Listen to a LOT of good mixes on them so you can identify WHEN you have a good mix too.
Good luck.
Ed
