electricabanana
basically what i am wondering is what part in the signal chain gives the most unwanted noise.
I am recording from mic -> mixer(preamp) -> sound card.
within the mixer i can adjuct gain for the mic channel as well as a fader for the mic channel and a fader for the overall mix.
i can adjust the soundcards sensitivity a bit too.
is there a rule for what faders etc should be turned up or down? currently i go with low gain, maximum soundcard sensitivity, and then adjust the mic channel fader till it is coming through at the desired volume.
is there an alternate method that would give a cleaner, more transparent sound? (i am not satisfied with the signal/noise ratio)
thanks in advance
thanks in advance
