Farview
There is extended headroom with 24 bit. 44.1k/24 bit has the same headroom as 48k/24 bit.
agreed!! So on that basis, if nothing else, I will tend to worry more about the 'bit-rate' rather than 44.1 or 48 !!Farview said:There is extended headroom with 24 bit. 44.1k/24 bit has the same headroom as 48k/24 bit.
Massive Master said:Bit DEPTH. Not bit RATE.
Big difference - Huge.
Massive Master said:Sidenote comment -
This is the first time I've ever seen results like this - Don't know if it's a "home-rec" thing or what.
Every single poll I've seen of full-time industry professionals in recent years puts around 70-80% of them squarely at the target rate (44.1kHz).
In this poll, almost half (more than half? Wasn't paying *that* much attention) record higher. Never saw that coming...
And the *third* of them recording at 48kHz?!? What's that all about?![]()
Hollowdan said:I always track in 24bit 96khz
Mix in 24bit 96khz
Master in 24bit 96khz
Enjoy a much better sounding CD in 16bit 44.1khz and realize it was worth all the trouble and extra money to build a machine actually capable of doing 24/96![]()
BigRay said:Probably because someone is spreading the BS that higher sample rates are superior.
Correct, the difference has more to do with the implementation than the sample rate.dgatwood said:Different hardware will exhibit different behavior.
The Nyquist theory does say that you can reproduce frequencies up to the limit accurately.dgatwood said:The Nyquist limit isn't the whole story. The Nyquist limit just says that you can reproduce the frequency, not that you can reproduce it accurately.
Those two sentences are in conflict with each other. Any small difference in volume that it would miss would be at a frequency higher than Nyquist, and therefor filtered out before the converters saw it.dgatwood said:The difference has nothing to do with hearing details in the high frequency content as many people contend, however. Any details in that content would, by definition, be at a higher frequency still, and thus well outside the human hearing range. The difference has to do with volume.
That would make perfect sense if it was even remotely how the reconstruction algorhythms work. It isn't.dgatwood said:The number of times you sample determines how accurate the waveform reconstruction can be. This results in a difference in the volume of signals as they approach the Nyquist limit. This is particularly significant for complex waveforms, as samples taken at two points in a complex waveform may not be anywhere near the peaks of the waveform. Oversampling can reduce this effect by using a moving average of multiple samples. This will yield a higher value than you would get with a single sample, but you still get rolloff as you approach the Nyquist point.
At 44.1k, the signal is 1db down at 19.5k. At 48k, there is no attenuation below 20k. (with my Motu 24I/O, not exactly top-notch stuff) How much 19.5k do you really have in your mixes? It could easily be made up for with a high shelf EQ.dgatwood said:Compounding this problem is the antialiasing filter that is applied during the sampling process. Whether applied in firmware as part of downsampling from an oversampled ADC or applied in hardware as an analog filter, the antialiasing filter rolls off all signals as they approach the Nyquist limit. The effect of this antialiasing filter begins at a much lower frequency than the Nyquist limit, resulting in a loss of volume at high frequencies.
However, because of oversampling, each of the 96,000 samples are based off of less data.dgatwood said:Because the Nyquist limit moves to a higher frequency as the sample rate increases, both of these two high frequency losses also move to higher frequencies. Thus, 96 kHz sampling provides audibly more accurate high frequency reproduction than 44.1 or 48 kHz sampling. When you listen to them in an A/B test, you will find that the 44.1/48 kHz sound dull by comparison due to this high frequency rolloff.
Practical physical filter restrictions aside - Nyquist sampling will indeed reproduce the intended Nyquist frequency accurately. This is equally true for a complex waveform as it is for a simple sine wave because, at the Nyquest limit, any differences are filtered out anyway.dgatwood said:The number of times you sample determines how accurate the waveform reconstruction can be. This results in a difference in the volume of signals as they approach the Nyquist limit. This is particularly significant for complex waveforms, as samples taken at two points in a complex waveform may not be anywhere near the peaks of the waveform.
SouthSIDE Glen said:But yet it works, and works accurately. That's because the waveform is reconstructed not by connecting the points of the individual samples, but rather by applying complex series of filtering and trigonemetric functions to the sample values themselves, mathematically "growing" the wave from the ground up (so to speak.)
