What not to do
  • Thread starter Thread starter MikeST
M
MikeST
Another beginner question, just for general discussion.
This weekend I'll be experimenting with my new (used) 488.
Everyone is always asking what a beginner should do to get started.
What are the most common mistakes?
What should you definately NOT do when starting out.
1 - After recording the perfect take, don't forget to turn off the record arming switch for the track you just recorded on and accidentally erase that once in a lifetime take!
2 - Don't overload your electronics by cranking the trim control and not having enough level on the channel and buss fader.
3 - Don't record with too much eq effect or it might be difficult to undo the changes in mixdown.
4 - Don't mixdown after several hours of tracking. Tired ears make for bad mixes.
5 - Don't mix on speakers you don't know the sound characteristics of with different types of music. Play a few CDs of music you are familiar with on them first so you'll know what the short-comings are and eq and position them as best as possible to sound good with your store bought CDs first so that when you mix on them, you'll get a more predictable result that will transfer well to other people's systems.
6 - Don't record a guitar and piano and keyboard sound all playing the same notes as this will just blur the definition of all the instruments. Use panning and different octaves of the spectrum to separate each instrument in the mix better.
7 - Don't forget to tune your instruments prior to the session to known tunning standards. I use my keyboard as a tunning reference for all my instruments.
8 - When singing, don't drink coffee or alcohol as both restrict your vocal chords.
9 - Don't forget to print this out and put it where you can see it in your studio!
10 - Don't forget to send me all your money! :D
How's that for negativity?
Cheers! :)
Some common "novice" misconceptions:
1) Thinking the mics and the room don't matter...
2) Not getting the instrument to sound good on its own before trying to record it....
3) Assuming that Radio Shack mics and Hosa cable are "more-than-enough" to get a pro sound because "it's all digital now"..........
4) Believing the sound quality comes from the gear and not the experience of the engineer....... (hint - a good engineer will turn out better results with a PortaStudio than a monkey with a Neve console!)
5) Beleiving that you really can fix-it-in-the-mix.....
- Don't jump-in blind... read up and understand some basic engineering techniques and concepts....
- Don't think getting more gear will necessarily get you better results... you have to "know how" before you can choose the best tools for YOU....
- Don't take it so seriously... your first efforts are likely going to be very rough-sounding.... accept that fact and learn from your mistakes.
