hello all,
I have asked this before but never realy got an answer. I have a dual tube compressor that clips out all the time when I use it on drums. I set the input level as low as I can set the attack fast and release slow. Ratio is 2:1 and I still get clipping as I gently pull turn the threashold to the left. I can't even get any real compression at all without the needle bouncing to the left when the snare hits. What causes this? How can it be resolved? I thought mabey better tubes would fix it but I haven't heard either way from this forum.
The compressor is a bellari rp282. It has two bellari tubes. I believe they are ec83.
I'll shut up about it and move on to better questions if you could help.
thanks,
ryan
thanks,
ryan
