I usually compose in the traditional way, with pencil and paper…and either with an
acoustic guitar or at the piano…or I may switch back-n-forth as I’m laying it down. The music usually falls in place pretty quick, then I’ll spend some time with a Thesaurus and rhyming dictionary getting all the lyrics worked out.
I avoid starting any tracking until I have the finished song.
Before I start to track, I lay down some scratch tracks. Usually that consists of me firing up my old Atari/Cubase combination (because it locks to my tape deck perfectly via SMPTE/MTC)…and I will find the BMP tempo of the song in Cubase and then spit out a Click from the Atari/Cubase (it’s actually triggering the Click from one of my synths) while simultaneously playing/recording a guitar and singing/recording the rough scratch tracks. Now I have a Click track and scratch vocal/guitar track on my tape deck.
(I usually pre-stripe my tapes with SMPTE before starting this process.)
Now it’s time to track for keeps…and that usually begins with the drums. My friend comes over and we lay down the drum tracks against the scratch tracks…to tape. The current SOP is to lay down the Kick to T1 and Snare to T2 and a stereo M/S pair of overheads to T3/T4. That takes up 4 of my 16 tape tracks which allows us to lay down three separate takes/song, which eats up 12 tracks, plus the 3 tracks that have the SMPTE, Click and Vox/Guitar)….so that’s 15 tracks of my 16 track deck. Sometimes I get fancy with the scratch vocal and guitar…and record them to their own tracks, which then fills up all 16 tracks.
We will normally track drums this way for three different songs per recording session....which takes up from 3-5 hours (with a lot of time spent BS-ing
I then dump all those tracks in one pass into my DAW (Samplitude)…and then after that, I’ll erase two of the three drum takes (tracks 5-12)….that leaves the four drum tracks, scratch, Click and the SMPTE, with 9 empty tracks on the tape. I like to record all my other stuff to the tracked drums, rather than just the scratch and Click tracks…but I also keep the Click going for everything, though I will adjust it’s level so it is not overpowering, and I usually pan it hard to one side.
I then proceed with tracking of other instruments…usually going either to a rhythm guitar or bass guitar…whatever feels better at that point...and from there continue with other instruments, normally doing all the rhythm/backing instruments first, and then the leads. Sometimes I may do my piano or organ parts before finishing up rhythm guitar parts…sometimes not. It’s all about the feel of the song at any given moment as I’m tracking…and my own mood.
Except for the stereo OH mics on the drums…I rarely record anything else with true stereo miking, though I have tracked my upright piano that way a few times…but now, I mostly use my Kurzweil electric piano, because honestly, it’s a PITA keeping the upright in tune!
Besides, most of my piano parts are for Rock/Pop…so I don’t get hung up about not having that concert piano sound.
I will double-track some things or do track duplicates in the DAW (mostly for organ/synth stuff)...and then create pseudo-stereo tracks that way.
Anyway…I can get several instruments done on those 9 empty tracks…and once I have a couple of other tracks, I may erase the scratch track(s) at that point, as I know the song well enough and have plenty of other instruments to guide me.
I then move on to vocals and leads (in no particular order, just how I feel). If I’ve used up the empty tracks on my tape deck for instruments, I will dump the tracks to the DAW again, leaving a few for cue purposes while erasing some to make room for more instruments and vocals/leads.
I’ve usually not needed to do more than 2 transfers from tape to DAW in order to get all my tracking done…but I think on one song or two I may have had to do a third transfer for one or two more tracks. When it goes into the DAW, it’s all been locked/synced via MTC. In my setup, I let the DAW/Samplitude chase the tape deck…and it works perfectly….at least it’s good enough for R&R!
After all the tracking is done and tracks have been all transferred to the DAW…I then edit/comp as needed…and that process is usually the most tedious for me and the most time consuming. My favorite part is the tracking, followed the mixing. A lot of guys hate tracking and enjoy mixing the most…but I really love the early stages of hearing the song emerge during tracking, and for me, that’s where most of the final mix is already happening…so by the time I get to editing and mixing, I’m pretty much just following through on an already established theme. I NEVER create the song or it’s “vibe” during editing or mixing…it’s all created during tracking, and the rest is just the fine-tuning process, which is why I like tracking the most.
Once edited in the DAW, I then use the DAW for playback (like a multitrack tape deck) and I bring 24 channels D/A out of the DAW and mix through my analog console, using outboard processing. The only “plugs” I use in the DAW are for “spot” EQs and small edits, but I never apply global EQ/compression/Reverb…while in the DAW. That is all done with outboard gear and via my console.
I mix down to a 2-track tape deck and simultaneously bounce the stereo playback output of the deck back into the DAW to capture the final stereo mix. I then use that for my “mastering stage”, though for me, the mastering has been mostly an experiment up to this point. I did my own mastering on the album I just finished, using the WAVES plugs linear EQ and L2 limiter across the mixes. I applied a lighter compression than what I could have done, preferring not to squash too hard as it has an effect on the overall tone…but I made the mixes loud enough to be close to commercial levels, needing only a couple of clicks of the volume knob to make them sound as loud as typical commercial releases when listening on most stereo systems.
I’m not sure if I will continue to “master” my own stuff or next time send it out. It was a LOT of work finding the right combination.
So that’s kinda my “process” reduced down as far as I can get it into a few paragraphs.
