What Is The Next Step Up From The Sound Card ?
  • Thread starter Thread starter smellyfuzz
smellyfuzz
smellyfuzz
Ok, I bought the Audiophile 24/96, you have all heard of it, I'd like to know;
1) Can I somehow upgrade the A/D converter somehow ?
Using s/pidf ?
2) If I decide I want better then a sound card can give me in the Digital Realm, what would that be ?
I still need to burn CD's please keep in mind.
All comments welcome.
Sean
You can always get an external AD converter that connects through SPDIF. Apogee, Lucid, and Cranesong all make them. You can get a Lucid AD9624 for about $750 or an Apogee Rosetta for like $1300. Those are some very high quality converters, and both can connect using SPDIF.
For better quality than those...think tape! Or RADAR.
H2H
H2H
or even more expensive standalones like prism, benchmark or DB, but me personally i'd rather get a car then a stand alone converter :eek:
he can't go tape cause wants it to be in the Digital realm
Anyone check out the Digitube from Presonus? It connects trough S/PDIF, and has tube pre's. I was wanting to check that out to hook it up to my Mia.
Thanks for the info guys.
I still have more questions;
Assuming I buy & use an external A/D converter using s/pdif,
will it bypass my sound card's converter ?
Would I use my sound card at all ?
Could a converter be used with a USB port ?
Will my sound card run into problems converting back to analogue at play back ?
Will I need an external D/A converter ? Is there a purpose to this ?
What are the advantages & disadvantages to external converters ?
Sean
Assuming I buy & use an external A/D converter using s/pdif, will it bypass my sound card's converter ?
Certainly. The SPDIF input on your soundcard is purely digital, A/D conversion must happen prior to hitting your soundcard's input (e.g. by your external A/D device!).
Yes, sorta. You'd still be using SPDIF. The term "soundcard" is confusing....there are digital only interfaces, which often called "digital soundcards", for instance.
Also, if you don't have an external D/A device, you will still use your soundcard's D/A for playback.
Soitenly! I know they exist, but I don't have any experience with USB interfaces....any USB audio interface is really going to be a "converter with a USB port."
In fact, anything digital with an analog input or output is doing conversion....that's why the self noise of a POD sounds like "lasdfkjadkwilalzzzkdieakfjzzzzz" and the self noise from your real amp sounds like "shhhhhhhhhhhhhhhhhhh". :)
Why would it? Inputs and outputs are really seperate things.
this ?
You would if you are unhappy with the way your soundcard sounds! A/D conversion is probably a little bit more important than D/A conversion in a home setup, but they are pretty close in importance.
1) The biggest advantage really is sound. Many people have a hard time hearing their converters because they try to listen for some kind of "sound"....they don't have a sound at all...it's what they lack in accuracy that gives them a particular sound quality.
An external converter will typically be of better quality because that's the way the boat floats. Amatures prefer soundcards and professionals prefer big rackmountable toys. I'm sure there are inherint benefits to an external design as well...seperate power supply, not being inside a noisy computer, lots of good shielding, plenty of room to work with...
Oh, another benefit to an external converter is that they can plug into any compatible digital interface. This is another reason why a professional converter would be implemented as an external unit instead of a soundcard....pro's simply have more wires and plugs :)
2) The disadvantage is usually price. External converters are often expensive because the target audience can hear the difference between a very robust and well-tested design and a cheaper, easier to implement design. We're talking anywhere from $100 per channel on the cheap side (which is about what a soundcard might run at) up to $1000-$2000+ per channel on the expensive side.
Slackmaster 2000
