lucid said:
oh so you can turn the 'fisher price' theme off? how?
Just go to Display Properties. The Themes tab is the default tab, and you can select between "Windows XP" and "Windows Classic". "Windows Classic" is the look from Windows 2000. And if you're REALLY a freak, you can select the "Windows Classic" theme and then go to the Appearance tab and actually select the old Windows 98 color/font scheme...
I should point out that you can actually have Windows XP use any GUI skins you want, since it uses the WindowBlind engine. I downloaded a MacOS skin the other day, which was too weird for me.
To use third-party skins, you have to download the WindowBlind program which will let you apply them.
You can even change the new XP Start Menu back to the Classic Start Menu. Basically, you can make everything function just like Windows 2000, which is less taxing on your CPU anyway. In fact, the only graphical effect I have turned on is ClearType, because it makes things so much easier for me to read.
Or you can let Windows choose the graphical effects according to your system specs, but whenever I do that, it just turns on all the effects anyway.
what are the different versions of XP and which one should i get? thanks...
The difference between Professional and Home Edition is mostly the addition of some networking features in Professional. It depends on what you need, but both are based on the same kernel and function exactly the same way.
Windows XP is much better than Windows 98; that's a given. The OS is actually faster than Win98 was on my computer, and I'm running a PII 266Mhz with 96MB of RAM! Don't know how others have fared, but I'm very satisfied with upgrading.
I agree with the guy above who says that an OS isn't worth it if it's not USABLE! I had Slackware Linux 8 installed, but couldn't do much with it except play with KDE and compile new kernel versions. Although, some interesting sound programs are being developed for Linux, which can be found at
http://www.linuxsound.at I have a feeling that someday, Linux will be a very viable contender for a DAW.
- bonch
stay animated
