What in the world is clipping??
  • Thread starter Thread starter JesusFreak
J
JesusFreak
Hey all,
I know I'm about to really let my newbieness shine really bright here but I've heard alot about clipping and really only know one thing about it. It's BAD! So knowing that, what is it?? and how do you prevent it??
Sorry for the ignorance guys, just trying to learn as much as possible. Thanks in advance for helping me.
God Bless!
Clipping means that a signal has overwhelmed the sensitivity of a transducer to properly respond to its changes. In the context of digital audio converters, every amplitude of the signal that is at or above the clipping level gets measured as the same maximum value. The waveform looks like a little flat-topped plateau until the signal amplitude descends below this point again. It's as if the real peak of the waveform here has been sheared off, hence the name clipping.
This obviously is not an accurate representation of the signal during the moments that it rises above this threshold, and it causes a particularly horrid-sounding distortion if it lasts more than an instant.
AlChuck,
WOW! I don't think I would have ever figured that one out. Thanks a bunch. Now is that only with vocals or can it happen to instruments also??
Is there a good way to prevent it?? (ie, peice of equipment, setting, certain setting on a piece of equipment) :)
Again, thanks a lot.
God Bless!
It can happen with any input - vocal, guitars, keyboards, drums...
You can either turn down the source of the sound, sing quieter, move the microphone further away, but the most common solution is probably to use a compressor. With proper settings, it will automatically adjust it's gain so that your recorder doesn't get overwhelmed.
Not only can it happen, the overdrive on electric guitars is nothing but clipping! :)
welcome freak,
yeah, anything can clip, not just vocal's(ANYTHING):D
RULE OF THUMB.......keep your signal at or below 0db. it's that simple really. i dont know what you record with, but everything has meter's of some sort, there is a 0db mark on the meter(sometime's it actually has the word"clip") check your level's, and make sure nothing is jumping over that mark before you hit record, and nothing should clip.
hope that helps man!
EDIT.......i am speaking from a digital stand point:D BUSTED!!
thank's sennheiser
Clipping = Distortion
If you send a signal from one device into another and the signal level is too high you will 'clip' the inputs.
Analog clipping is sometimes useable and even desired. Digital clipping is a horrendous chirping sound.
To amplify what TexRoadkill said, in the analog realm the signal is passed along as a continuous representation of the voltage of the incoming signal. When it hits the limits of the recording medium, as one example (in the case of analog tape, the physical limits of the magnetic particles to be aligned to the signal), it starts to distort, but the onset of the distortion is smooth, not a sudden on-off, so the "clipped" waveform is still rounded off. It's subtle right at the boundary area of the signal being just right or too hot, les subtle as you push it further with a hotter signal. This is what "tape saturation" is, and some amount of it is desireable, as it's a warm and aesthetically pleasing () distortion.
However, in an digital system, the sound is represented by "snapshots" of the waveform's amplitude, 44,100 of them every second in a standard audio CD, for example. And each of these samples can only contain a discrete value within the range defined by the number of bits used to represent the sample. A standard audio CD has a 16-bit resolution, meaning each sample has 65,536 possible values, with 0 representing silence and 65,535 representing the loudest sound.
If the signal is too hot for the analog-to digital converters, the samples it generates will have a value 65,535 at some level, and every amplitude that's hotter than this will too. So there can be no smooth transition to the distortion; it's either clipped or it's not. When this sound file is played back, the waveform is severely distorted becuase of the sudden flat top of the wave form, a condition that does not occur in nature. The resulting sound is far from pleasant, and there is no gray area where there's a "little" distortion that sounds good.
You're telling me,....
Thats what I'll be doing to the hedges this weekend! :rolleyes:
Seriously, I think Roadkill summed it up best.... "Clipping = Distortion"
... if you are working in the digital realm.
Levels are commonly pushed up to +5 peak VU working with analog tape depending upon the tape and the bias setup of the deck.
All you get out of a digital recording exceeding 0VU is a lot of unwanted noise and distortion. A digital signal that the converters have no way of handling. They cannot see a signal above 0VU. They have no idea that there is anything above 0.
Clipping, other wise known as "nearing saturation" in the analog universe is a good thing.
All depends on what you are working with.
Good points.
That's where the whole headroom issue comes into play. The more you can amplify a signal before it clips enough to sound like shit the more 'headroom' you have.
You guys are awesome....thanks to everyone that took their time to help me....I'm really excited about getting into this realm of recording, there is just soooo much to learn just to say that you have a basic understanding of it...I have been reading tons of threads, posts, e-books, reviews, you name it and I've probably been there somewhere downloading something to help me but to have you guys give answers from your experience and expertise is excellent.
Thanks again guys and anything else that you feel will be helpfull, please don't hesitate to let me know. Take care all!!
God Bless!
Now that that's out of the way, what format are you working with?
Welcome to the forum.;)
Hello Sennheiser,
I have decided to get the Korg D1600 so I will be working with digital. I'm just trying to figure all this stuff out as much as possible before I make the plunge...
God Bless!
