What good VTI instruments are out there?
  • Thread starter Thread starter Lienne
L
Lienne
Hey everyone! This is my first post here, and very likely not my last. I just installed cubase LE and am trying to turn some MIDI files I have into backing tracks for my band. There are strings, piano, etc. How would I go about doing this? I figured out how to apply a VTI instrument and I can get sound no problem. My main question I guess is what good VTI instruments are out there that I can use to make the track sound authentic? And am I supposed to be using the term "VTI instrument" in this way?
Thanks in advance for your assistance!
Depends what kinda "instruments" you're trying to use...Reason has a load of great pianos and keyboards if that's what you need. Also look into plug ins like Komplete
would reason also have orchestral settings? Like a trio of violins? or a harp?
Pardon my questions but what is a VTI instrument? Do you mean a VSTi? :confused:
I would highly recommend Kontakt 3. If it were possible, I would literally have sex with it.
I assume you mean VSTi which is Virtual Studio Instrument. It doesnt matter how you refer to it really, people will understand.
Kontakt really is your best bet. I did a lot, i mean a lot, of research into this and for an all around answer, its spot on. Its got a selection of strings, woodwinds, brass and perc from vienna symphonic library, which is the best orchestra VST around. Its got a great band section with some nice kits and bass.
The guitars sound bad, but then again all guitar samples are pretty poor imo, and these are at least partially useable for demos and quick stuff. The only thing it lacks is solo strings, all string patches are sections.
There is a whole host of synths and percussion. You can create your own instruments by binding wav files to various keys/MIDI inputs.
I got mine on student discount at £176, so if thats avaliable then go for it. Even at full price its the best thing around.
I've been using ezdrummer with good results. I'm not sure how well pattern files will transfer to LE. In higher versions, it's just a matter of drag and drop. If that doesn't work in LE, there's a work-around for it. But once you get the patterns in Cubase, the sounds are awesome.
Cheers,
if you do the upgrade to C4 then you'll also get some good vsti's included... search for KVR they list all kinds of stuff some of which are freeware...
Haha, yeah I definitely meant VST. Thanks everyone for the suggestions (and corrections). I'll definitely look into Kontakt. Sounds like just what I need =D
