what four track do I need
  • Thread starter Thread starter deerecs
D
deerecs
I have been using a spirit folio 10s for the phantom power equilization. From there i go into a fostex 160.
the mixer isn't mine and the fostex is on its last leg.
My question is... is there a fourtrack that has good eq and phantom power? and is it inexpensive?
jr
If you want to do a little upgrade with little cash, check ebay for a Tascam multi-track portastudio.
Why don't you consider using your computer for recording purposes?
i do not have a computer
this one (that i'm using) is my girlfriends
is the tascam multitrack portastudio a digital unit?
I guess my question should be "is there a cassettete tape 4-track that uses phantom power?"
portastudio is analog, and has no phantom.
There are both analog and digital PortaStudios.... you're better off with digital - at least you won't have to deal with the limitations of cheap analog...
(Cheap digital also has limitations, but less obvious than cheap analog)
thanks for the thoughts everyone.
i looked at the tascam 424 which looked like a good deal with decent (?) preamps. i guess i'll have to get an outboard phantom power unit as well.
anyhow, till next time.
jr
I would recommend you get an FMR Audio RNP as an outboard preamp.... one of the first cost-cutting measures used in PortaStudio-type gear is to cheap-out on the preamps......
