B
bcfromfl
I just purchased a new MikTek CV4 tube/transformer LDC to replace my KSM32. Among the differences between the mics is the result of now having vocals sit nicely ahead of the mix, while the Shure sounded like I was singing in the distance behind other tracks, no matter what degree of post-processing I used.
Miktek provides an individual response curve for each of their mics they sell, and I see that the CV4 has a subtle boost from 1K up. I suppose that might be part of what I'm noticing, but I could EQ the KSM32 as well and not get the results I'm hearing. The level I'm using through my Apogee Duet is essentially the same for both mics. I'm guessing that much of the CV4's magic comes from the transformer, but I don't understand how it could cause such a striking difference. Maybe the transformer is boosting the volume level beyond what I'm used to from the KSM32 on my virtual mixing board (Logic Pro), and an identical actual volume from the KSM32 would sit similarly in the mix? Of course, then I'd have harshness and "brittleness" to contend with. The CV4 is truly a silky mic by comparison.
The sensitivity of the CV4 is amazing as well -- I could sing without a pop filter when using the KSM32...but not any more! The soft expressions I can now evoke add a rich element to my recordings.
Anyone wanna buy a Shure?
Thanks in advance for your input.
-Bruce
-Bruce
I've read about folks turning their mics every which way to improve things, and perhaps if I turned
