N
neffi7
i've been seeing this everywhere i'm tryna learn to record...can someone pls explain to me waht they mean by FLAT??
thanks
thanks
recording flat, from what i understand is just recording without the tweaking anything, pretty much just natural recording, without compression or any other applications before you actually record.i've been seeing this everywhere i'm tryna learn to record...can someone pls explain to me waht they mean by FLAT??
thanks
thanks
hmm, i'll take the flat recording into consideration, usually i've been addin a lil compression going in because i like the way it makes my vocals sounds as a "starting point" for post-recording....Get the sound right at the core -- Mic -> Preamp -> Interface. If you can avoid any additional processing on the way in (EQ, dynamics, etc.), you're likely going to be in better shape later.
"Flat" for me means no EQ adjustment. All EQ dbs on 0, no outboard EQ, etc. That gets you the natural frequencies of the sound in the room. EQ can always be added later, but if it's added while you're recording, you can't get those natural frequencies back. Some of those natural frequencies will be things you'll want to get rid of, but again, do that in the mixing process. Nothing's worse than trying to bring up a frequency that isn't there because you EQ'ed it out while recording. I speak from unfortunate experience...
"Flat" can probably also indicate using as little gear as possible in the path between the mic and the recorder. The more circuitry the signal has to go through, the greater the possibility for the natural sound to be distorted and not reproduced faithfully.
That's my two bits.
and as homeboy above stated, it's also used in terms of frequency.....
And then if those particular settings don't work well in the context of the mix, you're screwed and you have to start from scratch.hmm, i'll take the flat recording into consideration, usually i've been addin a lil compression going in because i like the way it makes my vocals sounds as a "starting point" for post-recording....
But "flat" is indicative of not changing the source. "Clean" as in "no additional EQ" or "flat" as in "no additional EQ" -- The two are pretty much interchangeable in this context.fyi, technically that's recording "clean", or recording without any effects (the natural sound of the source). I haven't heard anyone use it in this way. It kind of works technically, but most people will know what you're sayng if you say "clean" vs. "flat"
