masteringhouse
www.masteringhouse.com
lotuscent said:yeah, that's what I do.
My question that I guess I did not articulate well enough is this : what is the optimum level for introducing the least amount of digital gain/reduction artifacts? At what level is a track in unity with the actual recorded signal? Or does that even matter? Obviously, to get the tracks as pure as possible, one would theoretically keep as close to this as possible, hence, the highest pre-clip level possible (full mix)... right...?
Does this make sense?
1 bit represents approximately 6 db. So if the maximum level you recorded at was -6, you would only be using 23 of the 24 bits (or 15 of the 16 bits) i.e. not full resolution. Of course less than -6 brings your resolution down further.
In order to get the best resolution (which is what I think you are getting at) you would try to get as close to 0 dBfs as possible without actually getting there. Remember a digital over is not really an "over". It is a measure of how many consecutive readings you have at 0 dBfs. This can vary from one digital device to another, so to play it safe I would only go to -1 dBfs maximum to ensure that you aren't clipping.
