C
cusebassman
Freakin' sweet
mshilarious said:Except it's not your thread to end, and it's not a perfect response. For example, a transformer-balanced preamp will interact with a dynamic mic. A variable input impedance preamp can also do this. Therefore, by changing the load on the mic, sometimes in complex ways, you can change the mic's signal itself.
Unless you consider the mic's signal to be the unloaded signal, which is not a real world application.
Also, of course a preamp can add things that weren't in the mic signal. This is one reason people stick things like tubes and transformers in preamps. But then mics can have circuits too, sometimes with tubes and transformers, sometimes not.
There is nothing sacred about the division of the circuit between mic and preamp, except for the need to avoid signal problems in transmission through a suitably long mic cable. It is possible to design a mic that only needs power, and spits out a line level signal. It is also possible to rip out the transformer from a dynamic mic, and become even more reliant on a preamp for gain.
Thus, the opinion that a microphone can be designed to create various sorts of signal distortions (mostly, but not entirely, a result of the transducer itself), but a preamp can only aspire to be a straight wire with gain is an inappropriately limited view of a system.
Goood points.
People talk about "color" in different preamps - if this didn't exist, then yes - maybe there would be a flatline plateau where the preamp simply boosted the signal from your mic perfectly, and garbage sounded like garbage, and great stuff sounded great... and then as you got cheaper and cheaper on the pre, the sound would degrade thusly.
However, this is not the case. Your mic pre might take a signal that is slightly off from sounding great and color it to sound just the way you want. So, as he said, it isn't as easy as aspiring to get a straight wire with a gain knob... however, for a lot of us with limited resources, that IS what we want, since we home recording enthusiasts usually need more all-purpose equipment... I use the DMP-3 on most of my tracks for that exact reason - it boosts my mic signal cleanly.
Since I can't afford a rack of pre's to the tune of thousands of dollars, I'll stick with the most useful tool I can find. Then collect some mics that do different things
