What am I missing here?
  • Thread starter Thread starter Purge
Purge
Purge
Traitorous Usurper
I'm using a Delta 44 and running N-Track, but for some reason (probably user stupidity) I'm only able to record 2 tracks at once instead of 4. I'm sure I'm missing something basic, and (to be honest) I guess I've just been too damn lazy to figure out what it is. I'm trying to grab some stuff off my ADATs to do mixing in the computer and this would be a hell of a lot easier than running each track individually and having to manually line them all up.
Click the hammer in the playback VU's and click "Select I/O channels" button.
Make sure you have all of your inputs selected.
There may be some kind of setting you need to make within the Delta control panel also. :confused:
Can't help ya with that though .... I don't use a Delta.
I have the 44 and N-track, I'm at work now (I'm on a break, I swear!) so this is going by memory.
You need to make sure all inputs are selected for recording. In the Input properties dialog, you want to select 1/2 and 3/4 (or something like that)
Then click the hammer in the input meter and make sure all 4 channels are armed to record. PM me if you still need help and I can check it out for you at home this evening.
Also, make sure in that dialog box that "Stereo-2 mono" is checked.
