C
Chip Hitchens
I really thought that I understood the basics of compression and limiting, but my results aren’t matching up with my expectations.
Using the onboard dynamics processor in my AW16G, I set up a limiter on one side of a stereo pair with a threshold of -2, different compression ratios between 1:10 and 1:infinity, very fast attack, decay around 350ms. There’s also a knee setting, which I assume should be hard for limiting. My goal was to keep anything really hot from going into digital distortion without affecting the natural dynamics of the recorded material.
For some reason, it made the effected channel slightly quieter across the board (when I bypassed the effect, both sides had similar levels). How is that happening? It shouldn’t do anything until the levels hit -2, right? I shouldn’t need to add output gain, since I’m not using it for traditional effect-type compression, should I? What am I doing wrong?
