so i'm using a Presonus Firestation to go into a laptop, recording mostly little keyboard lines (casio style) into Soundforge to add to tracks i've got going in Acid.
it appears to work fine, but then when i play it back it's like at half-speed or something... everything is set up at 48 khz (soundforge and acid) so that should be compatible -- are there other parameters i'm likely not having set correctly?
thanks!
ps someone just told me i can record directly into acid -- i'm clearly new at this, and i'd successfully loaded other audio into soundforge before so i was trying to stick with what i knew, but it aint workin'
thanks!
