A
abandonedbrain
I can spend 3-400 dollars. I have heard very few acoustic electrics that didn't have that rediculosly bright sound (which I would rather avoid). Any suggestions?
Very helpful. Thanks alot.cnix said:In your price range, I would not be concerned with the name on the guitar. If you are to concerned with the brand name, you may miss out on a nice no-name guitar. Stop by a store that has a wide selection and just spend some time with them. Listen to how they sound, how they play, how they are set-up and pick one that fits your needs. If you play in a band and ever think you will play out sometime, choose the acoustic-electric option. Plug it into an amp and play and see how it sounds. And last, once you have narrowed your choices down, have someone else play the guitar and sit in front so you can really "hear" how the guitar sounds.
The "bright" sounds you are refering to are often caused by laminated wood, not solid wood. In your price range, be prepared to by the laminated, however you may find one with a solid top.
The Seagull is on the same level as the others we mentioned, also has solid wood topabandonedbrain said:I guess my main question now is: What should I consider when deciding between a standard acoustic electric like a fender or alvarez, or go for something like a seagull? Thanks.
scrubs said:Since you mentioned that your main intention was to use the guitar for recording with microphones, I would suggest you get the best sounding guitar you can afford, regardless of whether or not it has electronics. You can always buy a cheap pickup, or get it retrofitted with electronics if you want to use it live. Unless you're willing to drop some serious change, the pickups/electronics in most acoustic/electrics are not going to sound good amplified, anyway.
marshall409 said:i would strongly advise against buying an acoustic guitar (or any guitar for that matter) online. you really really need to play everything you can and buy the one that feels best to you.
