L
LP2006
I have an oportunity to get some wharededale 8.1 actives for $175 shipped to my door. Anyone have any experience with these monitors? opinions? alternatives?
TheDewd said:Save up more and buy some KRK, Samson Rubicons, Events, etc..
Why settle for $175 Wharfesh*** ?
Why encourage mediocrity and cheapness instead of quality ?Thunder33 said:or spend the $175 for the set that has been pretty much renowned as the leader of active monitors in that price range.
This makes two threads where I have seen you telling people that they need to spend more than what they are planning to spend. Why don't you just bank roll all of us so we can have the obvious sweet set up that you have.....dewd.
TheDewd said:Why encourage mediocrity and cheapness instead of quality ?
Our society needs more quality, not more cheap products.
That last statement can only go so far.Thunder33 said:Because this forum is populated by people who are trying to do the best with what they have. Besides, I have heard music produced by inferior equipment that far surpasses some music made with thousands of dollars in gear. It is not the paintbrush, Dewd, it is the artist.
TheDewd said:That last statement can only go so far.
I agree that good things can be done with $500 monitors, one you get to know them well.
But Wharfesh*** ? You must be kidding. I prefer my RatShack Minimus 7 to those easily. When you decide to pay for monitors, you need to get something that is actually a step UP from most hi-fi small speakers.
I think it only comes down to what your objectives are.Thunder33 said:Again, you are right, we are wrong. Sorry.
TheDewd said:I think it only comes down to what your objectives are.
If you want to buy cheap now and improve one year from now, then go ahead.
Again, you might not agree with the need to improve, but most folks with better reputation than me who started on small cheap speakers have ended up improving shortly after. Bottom line is that if you're minimally serious, get some $500 monitors and build your system around those.
Skipping on the monitoring chain is not a thing you should encourage people to do,
Also, I listened to the sounds on your studio's website. I have a few constructive comments:
1) You seem to have a nice talent for mixing, since the mixes are well balanced and sound good overall.
2) The distorted guitar sound is very bad. It sounds (nearly) as awful as a BOSS MT-2 straight into the board. I would suggest investing in a POD or a good miked amp and redo those guitar tracks. It would improve the mix by at least 100%.
3) The drums are a little too much in the background for the genre. Especially the bass drum and snare, which should punch out some more. However, on the track #3, it seems the bass drum level is right on, but there is too much bass resonance (i.e the attack is very good, but too boomy).
BTW, the songs are quite cool...I dig this !
I'm a guitar intrumentalist myself.
Well, I still believe you should invest a little more, probably around $300-$400 and get some Events or KRK. At least, get the 8.2 and not the 8.1 if you choose to stick to Whafies. You won't want to waste too much time tweaking things between the Genelecs and your monitors.LP2006 said:I'm looking for some monitors that have decent clarity. Keep in mind I will be coming off a pair of sansui tower speakers, so im guessing im going to notice a big difference right away. Also keep in mind that in less than a year I will have access to some Genelecs. I just wont have access to them on a "whenever I feel like" basis! So, I need a pair of affordable monitors that I can use unitill then, and so I can do a bit of mixing when i can't get to those Genelecs.
TheDewd said:Well, I still believe you should invest a little more, probably around $300-$400 and get some Events or KRK. At least, get the 8.2 and not the 8.1 if you choose to stick to Whafies. You won't want to waste too much time tweaking things between the Genelecs and your monitors.
Well, I may dislike Wharfies, but between some 8.2 and TR5/RP5, I'd actually go with the Wharfies. Really, I wouldn't suggest using anything less than 6 inch for a woofer. Larger drivers generally have more power/better amps.LP2006 said:I wan't really planning on "tweaking between" whatever i get and the Genelecs at all. Those Genelec monitors are way beyond what I could even dream to afford at the moment, so i would be sure to take advantage of the opportunity and do all my final mixes on those. There will be no balancing between the two. I'll gladly trust those genelec monitors over whatever I end up getting!
Also, you said go with the 8.2 instead of the 8.1. But at that price I could get a pair of rockit 5's or tr5's. So are you recomending? The Wharefdales or the events/krk? Maybe you were refering to different models from the ones I looked at? You kind of just said to get events or krk's, you didn't suggest an actual specific monitor type at all.
TheDewd said:Well, I may dislike Wharfies, but between some 8.2 and TR5/RP5, I'd actually go with the Wharfies. Really, I wouldn't suggest using anything less than 6 inch for a woofer. Larger drivers generally have more power/better amps.
Well, when you design an amp, you can't simply take a design and increase the power. It's A LOT more complex than this. But basically, larger and more powerful power amps have more linearity when used at medium levels than a smaller amp used near it's full potential.LP2006 said:more power I can understand, but isn't that becasue it takes more power to drive the larger drivers? And better amps? What? I would think that the amps used in one series of monitors are essentailly the same just different power.
daav said:I'd appreciate some reference as to where the wharfe's fall short. When i was buying mine, it was at the tail end of a cycle where everyone and their brother were praising them for their quality for the price. No one i was reading/listening to was saying they were equivalant to the $500+ options of some of the best brands and models, but they were effectively universally praised. Now all of a sudden it seem they are considered a minor notch above computer speakers. OK, I will buy that fro people with more experience than me, but WHY? I'm really curious where the warfe 8.1's fall short. Anyone want to help a guys out with some specfiics?
Thanks,
Daav
